Upon commit, I get a warning regarding these DHCP server global options I have currently set in 1.4.0-epa2, that these will be unsupported for 1.5-rolling and onwards (because of KEA):
How to map these commands to CLI commands for KEA?
(On a side note, I’m not really sure if the code above is needed in my case, because the APs are on the same management VLAN as the controller and I don’t explicitly set an IP. But still, support for option 43 in CLI would be nice.)
You’re referring to Option 43 in the Sagitta documentation? I found this which might be helpful was added to 1.4 a while back ago. After you specify subnet there should be a vendor-option available as shown in the configuration code snippet in the link. Unless this has been removed in 1.5?
I just downloaded the latest 1.5 nightly and checked here’s what’s available.
# for entire shared-network-name:
set service dhcp-server shared-network-name TEST option vendor-option ubiquiti unifi-controller 192.168.20.20***
# or you can specify it for a specific subnet within:
set service dhcp-server shared-network-name TEST subnet 10.0.0.0/8 option vendor-option ubiquiti unifi-controller 192.168.20.20***
*** IP address of Unifi controller
