Hi there, i have been trying to set up a gre tunnel between two VyOS routers to send some multicast streams between them. Although i followed all the wiki guides i can’t get to set up the tunnel correctly. Everything is running virtually except the multicast source. I have a VM with linux connected via internal network to the R1, R1 with R2 also with internal network, and R2 directly bridged to the network with the multicast stream source.
R1 config:
bridge br1 {
address 3.3.3.1/30
address 10.128.0.221/16
aging 300
description “BRIDGE TO OUT”
hello-time 2
max-age 20
priority 0
stp false
bridge-group {
bridge br1
description “INT TO SEBA94”
duplex auto
hw-id 08:00:27:78:2a:5b
smp_affinity auto
speed auto
ethernet eth2 {
address 10.0.2.1/24
description R2R
duplex auto
hw-id 08:00:27:de:41:93
smp_affinity auto
speed auto
ethernet eth3 {
address 11.11.11.2/24
description PUTTY-CONNECTION
duplex auto
hw-id 08:00:27:91:d0:2f
smp_affinity auto
speed auto
loopback lo {
tunnel tun1 {
encapsulation gre-bridge
local-ip 10.0.2.1
multicast enable
parameters {
ip {
bridge-group {
bridge br1
remote-ip 10.0.2.2
R2 config:
bridge br1 {
address 3.3.3.2/30
address 10.128.0.220/16
aging 300
description “BRIDGE TUN1-ETH1”
hello-time 2
max-age 20
priority 0
stp false
bridge-group {
bridge br1
description “INT TO MCAST”
duplex auto
hw-id 08:00:27:1c:97:76
smp_affinity auto
speed auto
ethernet eth2 {
address 10.0.2.2/24
description R2R
duplex auto
hw-id 08:00:27:41:1b:a1
smp_affinity auto
speed auto
ethernet eth3 {
address 12.12.12.2/24
duplex auto
hw-id 08:00:27:a3:15:e1
smp_affinity auto
speed auto
loopback lo {
tunnel tun1 {
local-ip 10.0.2.2
multicast enable
parameters {
ip {
bridge-group {
bridge br1
remote-ip 10.0.2.1
Ping between bridges works, but not multicast. Also pinging from my VM to R1 bridge works but not to the bridge of R2.
I’m stuck here, any help is appreciated.
Thanks in advance
You should capture traffic for detailed research this problem.
At first on R2 sudo tcpdump -n -i tun1 then on R1 sudo tcpdump -n -i tun1. You can also use filter for tcpdump like host 239.0.0.1 with your multicast address
ps:// On my test server and client I added routes ip route add 224.0.0.0/4 dev e0
I can’t get it to work, what i don’t understand is why i can ping from bridge to bridge between routers and from client to bridge in R1, but not from client to bridge in R2. If i can’t get to do that i will never be able to get multicast through the tunnel because that means that the client can’t get to the network from R2, am i correct?
I think not quite. Can you draw network map on draw.io with all ip addresses (e.g client ip, server ip, multicast group). Did you have additional firewall rules? Did you saw multicast on R2 br1 and tun1?
As i said, pinging between bridges work, and between client and R1 bridge also. Ping from client to R2 bridge doesn’t work. If i play some multicast on VLC in my host machine and listen with tcpdump -i br1 on my R2 i can see the mcast traffic.
Here are both VyOS configs:
R1:
bridge br1 {
address 10.128.0.248/16
aging 300
hello-time 2
max-age 20
priority 0
stp false
bridge-group {
bridge br1
duplex auto
smp_affinity auto
speed auto
ethernet eth2 {
address 192.168.200.88/24
description R2R
duplex auto
smp_affinity auto
speed auto
ethernet eth3 {
duplex auto
smp_affinity auto
speed auto
loopback lo {
tunnel tun1 {
local-ip 192.168.200.88
multicast enable
parameters {
ip {
bridge-group {
bridge br1
remote-ip 192.168.200.89
R2:
bridge br1 {
aging 300
hello-time 2
max-age 20
priority 0
stp false
bridge-group {
bridge br1
duplex auto
smp_affinity auto
speed auto
ethernet eth2 {
address 192.168.200.89/24
description R2R
duplex auto
smp_affinity auto
speed auto
ethernet eth3 {
duplex auto
smp_affinity auto
speed auto
loopback lo {
tunnel tun1 {
local-ip 192.168.200.89
multicast enable
parameters {
ip {
bridge-group {
bridge br1
remote-ip 192.168.200.88
And route tables:
R1:
10.128.0.0/16 dev br1 proto kernel scope link src 10.128.0.248
11.11.11.0/24 dev eth3 proto kernel scope link src 11.11.11.2
127.0.0.0/8 dev lo proto kernel scope link src 127.0.0.1
192.168.200.0/24 dev eth2 proto kernel scope link src 192.168.200.88
R2:
10.128.0.0/16 dev br1 proto kernel scope link src 10.128.0.220
12.12.12.0/24 dev eth3 proto kernel scope link src 12.12.12.2
192.168.200.0/24 dev eth2 proto kernel scope link src 192.168.200.89
Ok, let’s try solve first problem with icmp Client and R2 bridge ip address. Enable promiscuous mode on virtualbox. Then run ping 10.128.0.220 from Client and capture traffic with tcpdump on R2 tun1.
I rebooted everything and now i can ping from client to br1 on R2 with response! even to different ip’s from the 10.128.0.0 network, now i have to configure the routers to pass multicast in any other way?
I couln’t get the multicast to work. I added the 224.0.0.0/4 route to the enp0s9 client interface, and set igmp-proxy on both routers and still can’t get it.
R1:
protocols {
igmp-proxy {
interface eth1 {
role downstream
interface eth2 {
role upstream
i can only get captured multicast on br1 of R2 if i request it with VLC from the host machine. Nothing if i do it from the client. And no traffic on tun1
