configure
set system hostname RIGHT
set interfaces dummy dum0
set interfaces dummy dum0 address 192.168.100.1/24
set interfaces ethernet eth0 address 10.255.255.2/30
set interfaces ethernet eth0 description 'Outside'
#set interfaces ethernet eth0 duplex 'auto'
#set interfaces ethernet eth0 speed ‘auto'
set interfaces ethernet eth1 address 172.16.1.1/24
set interfaces ethernet eth1 description 'Inside'
#set interfaces ethernet eth1 duplex 'auto'
#set interfaces ethernet eth1 speed 'auto
commit
set service dhcp-server shared-network-name LAN subnet 172.16.1.0/24 default-router '172.16.1.1'
set service dhcp-server shared-network-name LAN subnet 172.16.1.0/24 dns-server '172.16.1.1'
set service dhcp-server shared-network-name LAN subnet 172.16.1.0/24 domain-name 'internal-network'
set service dhcp-server shared-network-name LAN subnet 172.16.1.0/24 lease '86400'
set service dhcp-server shared-network-name LAN subnet 172.16.1.0/24 range rang01 start '172.16.1.100'
set service dhcp-server shared-network-name LAN subnet 172.16.1.0/24 range rang01 stop '172.16.1.254'
run generate vpn rsa-key bits 2048
rsa-key to /config/ipsec.d/rsa-keys/localhost.key
Your new local RSA key has been generated
The public portion of the key is:
0sAQO2335[long string here]
set interfaces tunnel tun0 encapsulation gre
set interfaces tunnel tun0 local-ip 10.255.255.2
set interfaces tunnel tun0 remote-ip 10.255.255.1
set interfaces tunnel tun0 address 10.10.10.2/30
## IPsec
set vpn ipsec ipsec-interfaces interface eth0
# IKE group
set vpn ipsec ike-group MyIKEGroup proposal 1 dh-group '2'
set vpn ipsec ike-group MyIKEGroup proposal 1 encryption 'aes128'
set vpn ipsec ike-group MyIKEGroup proposal 1 hash 'sha1'
# ESP group
set vpn ipsec esp-group MyESPGroup proposal 1 encryption 'aes128'
set vpn ipsec esp-group MyESPGroup proposal 1 hash 'sha1'
# IPsec tunnel
set vpn ipsec site-to-site peer 10.255.255.1 authentication mode pre-shared-secret
set vpn ipsec site-to-site peer 10.255.255.1 authentication pre-shared-secret MYSECRETKEY
set vpn ipsec site-to-site peer 10.255.255.1 ike-group MyIKEGroup
set vpn ipsec site-to-site peer 10.255.255.1 default-esp-group MyESPGroup
set vpn ipsec site-to-site peer 10.255.255.1 local-address 10.255.255.2
# This will match all GRE traffic to the peer
set vpn ipsec site-to-site peer 10.255.255.1 tunnel 1 protocol gre
set vpn rsa-keys rsa-key-name LEFT rsa-key <PUBLIC KEY FROM THE RIGHT>
set vpn ipsec esp-group MyESPGroup proposal 1 encryption aes128
set vpn ipsec esp-group MyESPGroup proposal 1 hash sha1
set vpn ipsec ike-group MyIKEGroup proposal 1 dh-group 2
set vpn ipsec ike-group MyIKEGroup proposal 1 encryption aes128
set vpn ipsec ike-group MyIKEGroup proposal 1 hash sha1
set vpn ipsec site-to-site peer 10.255.255.1 authentication id @RIGHT
set vpn ipsec site-to-site peer 10.255.255.1 authentication mode rsa
set vpn ipsec site-to-site peer 10.255.255.1 authentication rsa-key-name LEFT
set vpn ipsec site-to-site peer 10.255.255.1 remote-id @LEFT
set vpn ipsec site-to-site peer 10.255.255.1 connection-type initiate
set vpn ipsec site-to-site peer 10.255.255.1 local-address any
set vpn ipsec site-to-site peer 10.255.255.1 tunnel 1 local prefix 172.16.1.0/24
set vpn ipsec site-to-site peer 10.255.255.1 tunnel 1 remote prefix 192.168.0.0/24
After pulling my hair out of my head i have reached to a point where…
I have both PC1 and PC2 can ping each other as i have configured ospf.
The tunnel traffic is unencrypted as wireshark captures show clear pings and ospf hello packets same as the above screenshot
I am sharing the show conf commands outputs of both my Left and Right Routers
LEFT
Left# run sh configuration commands
set interfaces dummy dum0 address ‘192.168.255.1/24’
set interfaces ethernet eth0 address ‘10.255.255.1/30’
set interfaces ethernet eth0 description ‘Outside’
set interfaces ethernet eth0 hw-id ‘0c:0d:e2:57:0c:00’
set interfaces ethernet eth1 address ‘192.168.0.1/24’
set interfaces ethernet eth1 description ‘Inside’
set interfaces ethernet eth1 hw-id ‘0c:0d:e2:57:0c:01’
set interfaces ethernet eth2 hw-id ‘0c:0d:e2:57:0c:02’
set interfaces loopback lo
set interfaces tunnel tun0 address ‘10.10.10.1/30’
set interfaces tunnel tun0 local-ip ‘10.255.255.1’
set interfaces tunnel tun0 multicast ‘disable’
set interfaces tunnel tun0 remote-ip ‘10.255.255.2’
set protocols ospf area 0.0.0.0 network ‘10.10.10.0/30’
set protocols ospf area 0.0.0.0 network ‘192.168.0.0/24’
set protocols ospf area 0.0.0.0 network ‘192.168.255.0/24’
set service dhcp-server shared-network-name LAN subnet 192.168.0.0/24 default-router ‘192.168.0.1’
set service dhcp-server shared-network-name LAN subnet 192.168.0.0/24 dns-server ‘192.168.0.1’
set service dhcp-server shared-network-name LAN subnet 192.168.0.0/24 domain-name ‘internal-network’
set service dhcp-server shared-network-name LAN subnet 192.168.0.0/24 lease ‘86400’
set service dhcp-server shared-network-name LAN subnet 192.168.0.0/24 range rang01 start ‘192.168.0.100’
set service dhcp-server shared-network-name LAN subnet 192.168.0.0/24 range rang01 stop ‘192.168.0.254’
set system host-name ‘Left’
set system login user vyos authentication encrypted-password ‘$0000’
set system login user vyos authentication plaintext-password ‘’
set vpn ipsec esp-group MyESPGroup compression ‘disable’
set vpn ipsec esp-group MyESPGroup lifetime ‘3600’
set vpn ipsec esp-group MyESPGroup mode ‘tunnel’
set vpn ipsec esp-group MyESPGroup pfs ‘enable’
set vpn ipsec esp-group MyESPGroup proposal 1 encryption ‘aes128’
set vpn ipsec esp-group MyESPGroup proposal 1 hash ‘sha1’
set vpn ipsec ike-group MyIKEGroup close-action ‘none’
set vpn ipsec ike-group MyIKEGroup ikev2-reauth ‘no’
set vpn ipsec ike-group MyIKEGroup key-exchange ‘ikev1’
set vpn ipsec ike-group MyIKEGroup lifetime ‘28800’
set vpn ipsec ike-group MyIKEGroup proposal 1 dh-group ‘2’
set vpn ipsec ike-group MyIKEGroup proposal 1 encryption ‘aes128’
set vpn ipsec ike-group MyIKEGroup proposal 1 hash ‘sha1’
set vpn ipsec ipsec-interfaces interface ‘eth0’
set vpn ipsec site-to-site peer 10.255.255.2 authentication mode ‘pre-shared-secret’
set vpn ipsec site-to-site peer 10.255.255.2 authentication pre-shared-secret ‘MYSECRETKEY’
set vpn ipsec site-to-site peer 10.255.255.2 connection-type ‘initiate’
set vpn ipsec site-to-site peer 10.255.255.2 default-esp-group ‘MyESPGroup’
set vpn ipsec site-to-site peer 10.255.255.2 ike-group ‘MyIKEGroup’
set vpn ipsec site-to-site peer 10.255.255.2 ikev2-reauth ‘inherit’
set vpn ipsec site-to-site peer 10.255.255.2 local-address ‘10.255.255.1’
set vpn ipsec site-to-site peer 10.255.255.2 tunnel 1 allow-nat-networks ‘disable’
set vpn ipsec site-to-site peer 10.255.255.2 tunnel 1 allow-public-networks ‘disable’
set vpn ipsec site-to-site peer 10.255.255.2 tunnel 1 protocol ‘gre’
set vpn ipsec site-to-site peer @RIGHT authentication mode ‘rsa’
set vpn ipsec site-to-site peer @RIGHT authentication rsa-key-name ‘RIGHT’
set vpn ipsec site-to-site peer @RIGHT connection-type ‘respond’
set vpn ipsec site-to-site peer @RIGHT default-esp-group ‘MyESPGroup’
set vpn ipsec site-to-site peer @RIGHT ike-group ‘MyIKEGroup’
set vpn ipsec site-to-site peer @RIGHT ikev2-reauth ‘inherit’
set vpn ipsec site-to-site peer @RIGHT local-address ‘10.255.255.1’
set vpn ipsec site-to-site peer @RIGHT tunnel 1 allow-nat-networks ‘disable’
set vpn ipsec site-to-site peer @RIGHT tunnel 1 allow-public-networks ‘disable’
set vpn ipsec site-to-site peer @RIGHT tunnel 1 local prefix ‘192.168.0.0/24’
set vpn ipsec site-to-site peer @RIGHT tunnel 1 remote prefix ‘172.16.1.0/24’
set vpn rsa-keys rsa-key-name RIGHT rsa-key '0sA==================================
Right
Right:~$ show configuration commands
set interfaces dummy dum0 address ‘192.168.100.1/24’
set interfaces ethernet eth0 address ‘10.255.255.2/30’
set interfaces ethernet eth0 hw-id ‘0c:0d:e2:40:ba:00’
set interfaces ethernet eth1 address ‘172.16.1.1/24’
set interfaces ethernet eth1 hw-id ‘0c:0d:e2:40:ba:01’
set interfaces ethernet eth2 hw-id ‘0c:0d:e2:40:ba:02’
set interfaces tunnel tun0 address ‘10.10.10.2/30’
set interfaces tunnel tun0 local-ip ‘10.255.255.2’
set interfaces tunnel tun0 remote-ip ‘10.255.255.1’
set protocols ospf area 0.0.0.0 network ‘172.16.1.0/24’
set protocols ospf area 0.0.0.0 network ‘192.168.100.0/24’
set service dhcp-server shared-network-name LAN subnet 172.16.1.0/24 default-router ‘172.16.1.1’
set service dhcp-server shared-network-name LAN subnet 172.16.1.0/24 dns-server ‘172.16.1.1’
set service dhcp-server shared-network-name LAN subnet 172.16.1.0/24 domain-name ‘internal-network’
set service dhcp-server shared-network-name LAN subnet 172.16.1.0/24 lease ‘86400’
set service dhcp-server shared-network-name LAN subnet 172.16.1.0/24 range rang01 start ‘172.16.1.100’
set service dhcp-server shared-network-name LAN subnet 172.16.1.0/24 range rang01 stop ‘172.16.1.254’
set system host-name ‘Right’
set vpn ipsec site-to-site peer 10.255.255.1 authentication id ‘@RIGHT’
set vpn ipsec site-to-site peer 10.255.255.1 authentication mode ‘rsa’
set vpn ipsec site-to-site peer 10.255.255.1 authentication pre-shared-secret ‘MYSECRETKEY’
set vpn ipsec site-to-site peer 10.255.255.1 authentication rsa-key-name ‘LEFT’
set vpn ipsec site-to-site peer 10.255.255.1 connection-type ‘initiate’
set vpn ipsec site-to-site peer 10.255.255.1 default-esp-group ‘MyESPGroup’
set vpn ipsec site-to-site peer 10.255.255.1 ike-group ‘MyIKEGroup’
set vpn ipsec site-to-site peer 10.255.255.1 ikev2-reauth ‘inherit’
set vpn ipsec site-to-site peer 10.255.255.1 local-address ‘any’
set vpn ipsec site-to-site peer 10.255.255.1 tunnel 1 allow-nat-networks ‘disable’
set vpn ipsec site-to-site peer 10.255.255.1 tunnel 1 allow-public-networks ‘disable’
set vpn ipsec site-to-site peer 10.255.255.1 tunnel 1 local prefix ‘172.16.1.0/24’
set vpn ipsec site-to-site peer 10.255.255.1 tunnel 1 protocol ‘gre’
set vpn ipsec site-to-site peer 10.255.255.1 tunnel 1 remote prefix ‘192.168.0.0/24’
set vpn rsa-keys rsa-key-name LEFT rsa-key '0=================
