GRE with VyOS:
address 107.189.28.218/24
hw-id 00:16:97:55:ea:46
loopback lo {
tunnel tun0 {
address 10.7.0.1/30
encapsulation gre
ip {
ospf {
network point-to-point
mtu 1476
remote xxx
source-address xxx
The other end is Mikrotik router with config:
1 R name=“GRE” mtu=1476 actual-mtu=1476
local-address=xxx
remote-address=xxx keepalive=10s,10
dscp=inherit clamp-tcp-mss=yes dont-fragment=inherit
allow-fast-path=yes
Traffic going through here is having massive issues with SSL and loading content/pages. If I switch our my VyOS router with another Mikrotik, it works just fine with the same settings.
What your running into certainly sounds like an MTU issue. Have you tried seeing what MTU can get through the tunnel without fragmentation? You can do so from a linux host using “ping 23.136.232.33 -c 10 -M do -s 1446” and adjust the size until it works.
root@raspberrypi:~# ping xxx -c 10 -M do -s 1452
PING xxxxx 1452(1480) bytes of data.
From 107.189.28.218 icmp_seq=1 Frag needed and DF set (mtu = 1476)
ping: local error: message too long, mtu=1476
Something like 1400 works. So I set MTU on both sides to that with the same value for mss and clamping enabled. Same error.
vyos@vyos# set firewall options interface tun0 adjust-mss 1476
vyos@vyos# set interfaces tunnel tun0 mtu 1476
I’ve done this on both ends. Same outcome.
I’ve tried 1452, 1400, 1300, etc, and nothing works
Is there a other way I troubleshoot?
Maybe you can try to use Wireshark to debug this issue if you still want to build a tunnel with gre over ips. Otherwise you can build wireguard tunnel instead of gre. since wireguard will be more faster than grep tunnel.
While wireguard does offer great performance for an encrypted tunnel, Many nics offer offloading for GRE which will generally allow it to perform better, they also mentioned they are using a mikrotik on one end and while RouterOS7 does support wireguard the CPUs in most of the mikrotik devices are too weak to handle lots of traffic over wireguard. But that may not be an issue depending on their use case.
wireguard is the fastest vpn I ever know! At every scenarios, I replaced other vpn solution with wireguard vpn. Trust me, You will love vyos and wireguard vpn.
