I am facing a strange sporadic stability issue with one of my GRE over IPSec tunnels. In my environment I have 2 tunnels from my Vyos router (1.1.8) (located behind a NAT) terminating on a Mikrotik router on two different IPs (routed via two different ISPs). On the VyOS side the tunnels terminate on the same IP.
The tunnels usually function 100%. For some reason, at certain seemingly periods, there seems to be some sort of interruption in the tunnel that is routed over ISP2. Immediately afterwards IPSec phase 1 establishes but then it takes ages (e.g. many minutes) for phase 2 to establish. When I manually bring down the tunnels in many different ways, both phases always reestablish immediately.
I want to blame ISP2 but I during the time when the issue occurs, the IPs that the IPSec terminates on is reachable from both sides, no changes in trace route, P1 is up etc.
Below my configuration and logs. Any idea why this could be occurring and perhaps how to resolve it?
dummy dum1 {
address 169.254.200.2/32
description "ISP1"
dummy dum2 {
address 169.254.200.6/32
description "ISP2"
tunnel tun1 {
address 169.254.100.106/30
description "GRE ISP1"
encapsulation gre
local-ip 169.254.200.2
multicast disable
remote-ip 169.254.200.1
tunnel tun2 {
address 169.254.100.110/30
description "GRE ISP2"
encapsulation gre
local-ip 169.254.200.6
multicast disable
remote-ip 169.254.200.5
esp-group ESP-GROUP {
compression disable
lifetime 3600
mode tunnel
pfs enable
proposal 1 {
encryption aes128
hash sha1
ike-group IKE-GROUP {
dead-peer-detection {
action restart
interval 15
timeout 30
ikev2-reauth no
key-exchange ikev1
lifetime 28800
proposal 1 {
dh-group 2
encryption aes128
hash sha1
peer 12.28.12.33 {
authentication {
mode pre-shared-secret
connection-type initiate
default-esp-group ESP-GROUP
description "ISP1"
ike-group IKE-GROUP
ikev2-reauth inherit
local-address 172.16.2.22
tunnel 1 {
allow-nat-networks disable
allow-public-networks disable
local {
prefix 169.254.200.2/32
protocol gre
remote {
prefix 169.254.200.1/32
peer 19.17.32.65 {
authentication {
description "ISP2"
ike-group IKE-GROUP
tunnel 1 {
local {
prefix 169.254.200.6/32
protocol gre
remote {
prefix 169.254.200.5/32
Jan 17 02:02:34 vr1 pluto[3079]: packet from 19.17.32.65:500: ignoring Vendor ID payload [Cisco-Unity]
Jan 17 02:02:34 vr1 pluto[3079]: packet from 19.17.32.65:500: received Vendor ID payload [Dead Peer Detection]
Jan 17 02:02:34 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: responding to Main Mode
Jan 17 02:02:35 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Peer ID is ID_IPV4_ADDR: ‘19.17.32.65’
Jan 17 02:02:35 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sent MR3, ISAKMP SA established
Jan 17 02:02:35 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: cannot respond to IPsec SA request because no connection is known for 169.254.200.6/32===172.16.2.22[172.16.2.22]…19.17.32.65[19.17.32.65]===169.254.200.5/32
Jan 17 02:02:35 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_ID_INFORMATION to 19.17.32.65:500
Jan 17 02:02:45 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0x1266518e (perhaps this is a duplicated packet)
Jan 17 02:02:45 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_MESSAGE_ID to 19.17.32.65:500
Jan 17 02:02:55 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0x1266518e (perhaps this is a duplicated packet)
Jan 17 02:02:55 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_MESSAGE_ID to 19.17.32.65:500
Jan 17 02:03:06 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: cannot respond to IPsec SA request because no connection is known for 169.254.200.6/32===172.16.2.22[172.16.2.22]…19.17.32.65[19.17.32.65]===169.254.200.5/32
Jan 17 02:03:06 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_ID_INFORMATION to 19.17.32.65:500
Jan 17 02:03:16 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0xd5302499 (perhaps this is a duplicated packet)
Jan 17 02:03:16 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_MESSAGE_ID to 19.17.32.65:500
Jan 17 02:03:26 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0xd5302499 (perhaps this is a duplicated packet)
Jan 17 02:03:26 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_MESSAGE_ID to 19.17.32.65:500
Jan 17 02:03:39 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: cannot respond to IPsec SA request because no connection is known for 169.254.200.6/32===172.16.2.22[172.16.2.22]…19.17.32.65[19.17.32.65]===169.254.200.5/32
Jan 17 02:03:39 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_ID_INFORMATION to 19.17.32.65:500
Jan 17 02:03:49 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0x2c2c06d0 (perhaps this is a duplicated packet)
Jan 17 02:03:49 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_MESSAGE_ID to 19.17.32.65:500
Jan 17 02:03:59 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0x2c2c06d0 (perhaps this is a duplicated packet)
Jan 17 02:03:59 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_MESSAGE_ID to 19.17.32.65:500
Jan 17 02:04:11 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: cannot respond to IPsec SA request because no connection is known for 169.254.200.6/32===172.16.2.22[172.16.2.22]…19.17.32.65[19.17.32.65]===169.254.200.5/32
Jan 17 02:04:11 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_ID_INFORMATION to 19.17.32.65:500
Jan 17 02:04:21 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0x1885828d (perhaps this is a duplicated packet)
Jan 17 02:04:21 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_MESSAGE_ID to 19.17.32.65:500
Jan 17 02:04:31 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0x1885828d (perhaps this is a duplicated packet)
Jan 17 02:04:31 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_MESSAGE_ID to 19.17.32.65:500
Jan 17 02:04:44 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: cannot respond to IPsec SA request because no connection is known for 169.254.200.6/32===172.16.2.22[172.16.2.22]…19.17.32.65[19.17.32.65]===169.254.200.5/32
Jan 17 02:04:44 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_ID_INFORMATION to 19.17.32.65:500
Jan 17 02:04:54 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0xb83bd39b (perhaps this is a duplicated packet)
Jan 17 02:04:54 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_MESSAGE_ID to 19.17.32.65:500
Jan 17 02:05:04 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0xb83bd39b (perhaps this is a duplicated packet)
log trimmed for repeated message
Jan 17 02:20:11 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0xab0d37f0 (perhaps this is a duplicated packet)
Jan 17 02:20:11 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_MESSAGE_ID to 19.17.32.65:500
Jan 17 02:20:21 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0xab0d37f0 (perhaps this is a duplicated packet)
Jan 17 02:20:21 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_MESSAGE_ID to 19.17.32.65:500
Jan 17 02:20:34 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: cannot respond to IPsec SA request because no connection is known for 169.254.200.6/32===172.16.2.22[172.16.2.22]…19.17.32.65[19.17.32.65]===169.254.200.5/32
Jan 17 02:20:34 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_ID_INFORMATION to 19.17.32.65:500
Jan 17 02:20:44 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0x1b32ced9 (perhaps this is a duplicated packet)
Jan 17 02:20:44 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_MESSAGE_ID to 19.17.32.65:500
Jan 17 02:20:54 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: Quick Mode I1 message is unacceptable because it uses a previously used Message ID 0x1b32ced9 (perhaps this is a duplicated packet)
Jan 17 02:20:54 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_MESSAGE_ID to 19.17.32.65:500
Jan 17 02:21:06 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: cannot respond to IPsec SA request because no connection is known for 169.254.200.6/32===172.16.2.22[172.16.2.22]…19.17.32.65[19.17.32.65]===169.254.200.5/32
Jan 17 02:21:06 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24187: sending encrypted notification INVALID_ID_INFORMATION to 19.17.32.65:500
Jan 17 02:21:09 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24190: initiating Quick Mode PSK+ENCRYPT+TUNNEL+PFS+UP to replace #24181 {using isakmp#24187}
Jan 17 02:21:10 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24190: Dead Peer Detection (RFC 3706) enabled
Jan 17 02:21:10 vr1 pluto[3079]: “peer-19.17.32.65-tunnel-1” #24190: sent QI2, IPsec SA established {ESP=>0x00d643f4 <0xc9b1e94b}
