after trying for countless hours, I’m about to give up.
coming from EdgeOS, I thought this would be easier…
I have everything else up and running: the webserver is
reachable from the internet, the VPN works and hosts on
the LAN subnet can’t be reached from DMZ but the other
way it’s possible. the only thing I seem to be unable to
get running is Hairpin NAT. it drives me crazy. I read
the docs, searched the forum for hours. no success so far.
any hints would be greatly appreciated, thnx!
regards,
michael
irrelevant stuff (DNS; VPN; DHCP; etc) left out.
192.168.1.1/24 LAN VyOS (eth0)
10.10.10.1/24 DMZ VyOS (eth2)
10.10.10.150/24 WWW server
X.X.X.X WAN VyOS (eth1)
set firewall name DMZ-ISOLATE default-action 'accept'
set firewall name DMZ-ISOLATE rule 1 action 'drop'
set firewall name DMZ-ISOLATE rule 1 description 'DROP DMZ to LAN'
set firewall name DMZ-ISOLATE rule 1 destination address '192.168.1.0/24'
set firewall name DMZ-ISOLATE rule 1 log 'disable'
set firewall name DMZ-ISOLATE rule 1 protocol 'all'
set firewall name DMZ-ISOLATE rule 1 state established 'disable'
set firewall name DMZ-ISOLATE rule 1 state invalid 'enable'
set firewall name DMZ-ISOLATE rule 1 state new 'enable'
set firewall name DMZ-ISOLATE rule 1 state related 'disable'
set firewall name WAN-IN default-action 'drop'
set firewall name WAN-IN rule 10 action 'accept'
set firewall name WAN-IN rule 10 state established 'enable'
set firewall name WAN-IN rule 10 state related 'enable'
set firewall name WAN-IN rule 20 action 'drop'
set firewall name WAN-IN rule 20 description 'Drop invalid state'
set firewall name WAN-IN rule 20 state invalid 'enable'
set firewall name WAN-IN rule 50 action 'accept'
set firewall name WAN-IN rule 50 destination address '10.10.10.150'
set firewall name WAN-IN rule 50 destination port '80'
set firewall name WAN-IN rule 50 protocol 'tcp'
set firewall name WAN-IN rule 50 state new 'enable'
set firewall name WAN-LOCAL default-action 'drop'
set firewall name WAN-LOCAL rule 20 action 'accept'
set firewall name WAN-LOCAL rule 20 icmp type-name 'echo-request'
set firewall name WAN-LOCAL rule 20 protocol 'icmp'
set firewall name WAN-LOCAL rule 20 state new 'enable'
set firewall name WAN-LOCAL rule 30 action 'drop'
set firewall name WAN-LOCAL rule 30 destination port '22'
set firewall name WAN-LOCAL rule 30 protocol 'tcp'
set firewall name WAN-LOCAL rule 30 recent count '4'
set firewall name WAN-LOCAL rule 30 recent time '60'
set firewall name WAN-LOCAL rule 30 state new 'enable'
set firewall name WAN-LOCAL rule 31 action 'accept'
set firewall name WAN-LOCAL rule 31 destination port '22'
set firewall name WAN-LOCAL rule 31 protocol 'tcp'
set firewall name WAN-LOCAL rule 31 state new 'enable'
set firewall name WAN-LOCAL rule 40 action 'accept'
set firewall name WAN-LOCAL rule 40 description 'Allow established/related'
set firewall name WAN-LOCAL rule 40 state established 'enable'
set firewall name WAN-LOCAL rule 40 state related 'enable'
set firewall name WAN-LOCAL rule 50 action 'drop'
set firewall name WAN-LOCAL rule 50 description 'Drop invalid state'
set firewall name WAN-LOCAL rule 50 state invalid 'enable'
set interfaces ethernet eth0 address '192.168.1.1/24'
set interfaces ethernet eth0 description 'LAN'
set interfaces ethernet eth0 ip 'enable-proxy-arp'
set interfaces ethernet eth1 address 'dhcp'
set interfaces ethernet eth1 description 'WAN'
set interfaces ethernet eth1 firewall in name 'WAN-IN'
set interfaces ethernet eth1 firewall local name 'WAN-LOCAL'
set interfaces ethernet eth2 address '10.10.10.1/24'
set interfaces ethernet eth2 description 'DMZ'
set interfaces ethernet eth2 firewall in name 'DMZ-ISOLATE'
set nat destination rule 100 description 'allow http -> webserver'
set nat destination rule 100 destination port '80'
set nat destination rule 100 inbound-interface 'eth1'
set nat destination rule 100 protocol 'tcp'
set nat destination rule 100 translation address '10.10.10.150'
set nat destination rule 110 description 'Hairpin NAT'
set nat destination rule 110 destination address 'IP_ADDRESS_WAN'
set nat destination rule 110 destination port '80'
set nat destination rule 110 inbound-interface 'eth1'
set nat destination rule 110 protocol 'tcp'
set nat destination rule 110 translation address '10.10.10.150'
set nat destination rule 110 translation port '80'
set nat source rule 100 outbound-interface 'eth1'
set nat source rule 100 source address '192.168.1.0/24'
set nat source rule 110 outbound-interface 'eth1'
set nat source rule 110 source address '10.10.10.0/24'
set nat source rule 110 translation address 'masquerade'
set nat source rule 120 description 'Hairpin NAT'
set nat source rule 120 destination address '10.10.10.150'
set nat source rule 120 destination port '80'
set nat source rule 120 outbound-interface 'eth1'
set nat source rule 120 protocol 'tcp'
set nat source rule 120 source address '192.168.1.0/24'
set nat source rule 120 source port '80'
set nat source rule 120 translation address 'masquerade'
