mc1903
#1
I am looking for help to understand a suitable physical hardware spec for a 2 port 10 Gbps router?
Is wire speed IPv4 inter-VLAN routing possible and if so, up to what packet size?
I will have approx. 10 VLANs on each of the ports, using VLAN tagging.
Simple static routing is preferred over OSPF or BGP.
What should I be looking at in terms of:
- CPU (# cores / core speed / features)
- Memory
- NIC features (offload/etc) - Are there any 10 Gbps NIC’s to avoid?
- Storage (assuming minimal for OS boot)
Many Thanks
M
roedie
#2
I would say all reasonable hardware would give you 10Gbit wire speed.
I have an intel Silver 4210 (overkill) with 128G memory (even more overkill) a four port XL710 an just the smallest SSD I could find.
10Gbit is no problem at all as long as the packet size is >100 bytes.
mc1903
#3
Thank you @roedie.
Your spec is a bit more than I was planning on
I will start with a 4/8 core E5-2600 v3 with 32GB and see what happens.
Cheers
M
roedie
#4
I have been doing 10gbit on a E5-2650 with 16G. No problems there.
mc1903
#5
Cool. I have an E5-2690 v3 and 32GB so I can test this. Thanks again.
