Is it possible to use wan acceleration/optimisation between two IPsec tunnel endpoint ?
Can you explain a bit more please?
I am using ipsec tunnel between two remote endpoint using vyos. I am looking for improving throughput between this two endpoint. Can wan acceleration be useful ? If yes how can I integrate it with vyos?
vyatta has partnered with reverbed for this purpose (Very cool: Riverbed and Vyatta partner for all-in-one router, WAN applianceĀ | Network World)
https://www.riverbed.com/newsletter/how-wan-optimization-works.html
Hello, @hiteshhapani!
You can use any WAN-optimization software or hardware solution in-the-middle between end-users and VyOS, to process unencrypted traffic, which then will be encrypted by VyOS and transmitted to the remote site.
If you want, you may make also a feature request on the Phabricator with a detailed description of what you want, and we will see if this feature can be implemented in VyOS itself.
