You can use not standard port for ssh, for example 8822, 2222, 64254
set service ssh port '8822'
If possible it will be a best practice to allow only predefined IP for ssh.
Also if possible, use default action DROP for firewall, but it depends. And allow only what you want/know.
An example firewall that allows ssh from 203.0.113.1 and 192.168.122.1
Also, it deny ICMP for network 10.0.0.0/23.
As for me, deny all ICMP it’s a bad idea. But you can try.
set firewall group address-group ALLOW-SSH address '203.0.113.1'
set firewall group address-group ALLOW-SSH address '192.168.122.1'
set firewall group network-group NET network '10.0.0.0/23'
set firewall name WAN-IN default-action 'accept'
set firewall name WAN-IN rule 10 action 'accept'
set firewall name WAN-IN rule 10 destination port '22'
set firewall name WAN-IN rule 10 protocol 'tcp'
set firewall name WAN-IN rule 10 source group address-group 'ALLOW-SSH'
set firewall name WAN-IN rule 20 action 'drop'
set firewall name WAN-IN rule 20 destination port '22'
set firewall name WAN-IN rule 20 protocol 'tcp'
set firewall name WAN-FW-IN default-action 'accept'
set firewall name WAN-FW-IN rule 10 action 'drop'
set firewall name WAN-FW-IN rule 10 destination group network-group 'NET'
set firewall name WAN-FW-IN rule 10 protocol 'icmp'
set interfaces ethernet eth0 firewall in name 'WAN-FW-IN'
set interfaces ethernet eth0 firewall local name 'WAN-IN'
