On ower Vyos server we have ower own ASNumber added and ip ranges, i have a friend who whants to add/announce hes own ASNumber and Ip Range on ower router, as Sub"Customer".
I know is sompting with Import/Export but i dont fiind any examples or i have to create a session with ower AS / 1 IPv4 ?
It`s depends , if you have your own public AS and your customer needs to announce their prefixes (these prefixes are their own). Therefore, you must speak to your local ISP to allow you to cross traffic with these
or
Also , you can create an ebgp session with your customer and you only need to do the policy import/ export ,this AS allows traffic to cross over to your upstream ISP.
You can configure all bgp sessions on one router.
Add policy prefix-list, route-map for import. For example with a biggest local-preference.
And update your route-map to neighbours who’s you want to send new prefixes for export.
Maybe I can’t get some information.
Is the customer has his own router with his own ASN and own prefixes?
If yes, just create a new one BGP session with him. And export his prefixes to ISP’s.
If for some reason you want the second router, it depends on your network topology.
I think Viacheslav’s last comment is the most common solution , it’s just create a BGP session with him (EBGP ) and then you create the policy (import/export) that you need. It’ll be something like this :
customer ASN => your ASN => ISP ASN
finally, talk with your local ISP and announce these new prefixes (if it is necessary )
Hello, i made the server with vyos, i setup hes as and prefixes on hes router.
I notice ower ISP to announce the new prefixes, is made.
The problem is the session and the config i have to do it in ower router and the way i connect cutomer router (on one port from ower router or from switch)
If someone can give us a hand to setup this i`m ready to pay , just pm me skype, fb, mail… (Paypal, By Card, Bank …etc)
This is sompting i never made and i dont whant to brake ower live router to make problems.
Bgp session should be configured on both sites. You configure own site, the customer configure own site. If you use switch you can add a separate vlan for it. The both options will work.
