Hi All
I’ve been playing with VyOS for a little while now just for my home internet connection, but I am coming across some issues which I’m not whether it’s me or there are issues.
I should say I’m running VyOS 1.2.0-rc11.
The first issue I’m seeing is with flow-accounting. I like to use it to see who hogging the bandwidth, but ntop is only showing me internal traffic and no external traffic. I think I remember reading somewhere that the flows are only recording the source addresses, not the destination, so I need me pppoe interface is see the remote addresses, although i think this may still be problematic as the destination IP is my post-nat (external) address, but it’ll be better than nothing.
This is my config. eth1 and 2 are internal networks.:
duplex auto
hw-id 00:50:56:a2:4f:e2
policy {
route pppoe-out
pppoe 0 {
default-route auto
firewall {
in {
mtu 1492
name-server none
password ****************
user-id **
smp-affinity auto
speed auto
flow-accounting {
interface eth1
interface pppoe0
interface eth2.10
interface eth2.11
netflow {
engine-id 1
sampling-rate 100
server 192.168.0.247 {
port 2055
timeout {
expiry-interval 60
flow-generic 300
icmp 300
max-active-life 604800
tcp-fin 300
tcp-generic 3600
tcp-rst 120
udp 300
version 9
syslog-facility daemon
If I look at iptables, it seems to be handing packet info to pmacct:
Chain VYATTA_CT_PREROUTING_HOOK (1 references)
1347 474K NFLOG all -- eth2.11 * 0.0.0.0/0 0.0.0.0/0 nflog-group 2 nflog-range 64 nflog-threshold 10
1482K 96M NFLOG all -- eth2.10 * 0.0.0.0/0 0.0.0.0/0 nflog-group 2 nflog-range 64 nflog-threshold 10
3240K 4195M NFLOG all -- pppoe0 * 0.0.0.0/0 0.0.0.0/0 nflog-group 2 nflog-range 64 nflog-threshold 10
1014K 860M NFLOG all -- eth1 * 0.0.0.0/0 0.0.0.0/0 nflog-group 2 nflog-range 64 nflog-threshold 10
21M 18G RETURN all -- * * 0.0.0.0/0 0.0.0.0/0
…but flow-accouting is showing nothing on the pppoe interface:
flow-accounting for [pppoe0]
Src Addr Dst Addr Sport Dport Proto Packets Bytes Flows
Total entries: 0
Total flows : 0
Total pkts : 0
Total bytes : 0
…so it seems there is something not right somewhere.
If someone it able to point me in the right direction, that would be great.
Thanks
Chris…
