Help with policy based routing when SNAT is used
Hello, i’m having trouble with policy base routing, and can use some help.
I am planning to limit bandwidth of certain IPs to 64kbit during night hours. On the network IP hosts are assigned a DHCP ip address based on mac which corresponds to the range where I need to limit bandwidth at night.
I have a traffic-policy shaper that works, however, the syntax of the that command only allows one destination address. To work around this, I am attempting to use PBR to mark packets from a specific destination address range. It does not seem to work, from what I can tell the PBR policy is not marking the packets or the traffic-policy is not matching the packets.
The router has NAT on the local subnet and I am filtering by local destination IP address
My configuration is below, how is the route policy processed and when? what would cause it not to match the marked packets?
address-group ADDR_RANGE_NIGHT_LIMIT {
     address XX.XX.XX.100-XX.XX.XX.199
 route POLICY_NIGHT_LIMIT_MARK {
     description "This marks pakets on  in the group for matching in shaper"
     rule 100 {
         destination {
            group {
         set {
             mark 8000
 shaper POLICY_NIGHT_LIMIT {
     class 100 {
         bandwidth 64kbit
         description "rate limit policy for devices DHCP assined in the range"
         match MATCH_ADDR_MARK {
             mark 8000
     default {
         bandwidth 1000Mbit
     address dhcp
     description WAN
     duplex auto
     firewall {
         in {
             name WAN-IN-4
         local {
             name WAN-LOCAL
       policy {
     smp-affinity auto
     speed auto
     address xx.xx.0.xx/24
     description LAN_PRIVATE
     duplex auto
     firewall {
         in {
             name LAN_PRIVATE-IN
         out {
             name LAN_PRIVATE-OUT
      policy {
     smp-affinity auto
     speed auto
     traffic-policy {
         out POLICY_NIGHT_LIMIT
type or paste code here
Probably, you mark rules sees packets as they arrive on WAN: Destination IP is still your masqueraded LAN address, so you can’t match on LAN address.
Easiest to group those addresses in a “binary” range , like a /26 or /25 network, so you can add that range to shaper on LAN interface
