How i can monitor the cpu of my vyos and memory at real time i are testing some device with pppoe for use a spare vyos as brass on my network
Thanks
Thanks
For example:
sudo top
Mine doesn’t show me the temp of my CPU (Ryzen 7 1700). Do you know a program that does?
You might have to compile a custom ISO to get it, I’m not sure.
lm-sensors is present in 1.3/1.4 releases.
Ah, you’re right! Then it’s just a matter of running this then to see your temperature:
sensors
