on Juniper decvices if I had a very long piece of conf I could hide it using
apply-flags omit;
that section will be hidden, and replaced by a simple comment, for example
root@r1# set firewall family inet filter protect-re apply-flags omit
and the result would be
root@r1# show firewall
family inet {
filter protect-re { /* OMITTED */ };
and if you need to see the hidden part you can do it using
show configure | display omit
Is there anything similar in vyos ?
We plan a general system of flags for the new configuration backend. For example, one long-standing idea is an “ephemeral” flag that will cause the system to omit nodes when saving the config, so that VRRP transition scripts can safely insert temporary configurations without worrying about altering the permanent baseline config.
A display omit flag is also a good idea. It will only be possible after the last bits of legacy code are gone, though — but that’s pretty soon now, there are only two legacy components left in 1.4!
Ok I got it … I will wait for the “omit” feature
Thanks for the info
