This is with VyOS 1.5-rolling-202501110007. I’m trying to use high-availability virtual-server to balance HTTP traffic across multiple backends and it ends up sending 100% of the connections to a single backend unless I manually make changes via ipvsadm
Here’s the config:
virtual-server http {
address 50.106.9.46
algorithm weighted-round-robin
delay-loop 1
port 8080
protocol tcp
real-server 172.16.0.1 {
port 80
real-server 172.16.0.2 {
port 80
real-server 172.16.1.1 {
port 80
real-server 172.16.1.2 {
port 80
real-server 172.31.255.1 {
connection-timeout 5
port 80
real-server 172.31.255.2 {
port 80
Running a load test from an external server with 256 open connections results in all of the traffic going to the same back end:
TCP 50.106.9.46:http-alt wrr
-> 172.16.0.1:http Masq 1 0 0
-> 172.16.0.2:http Masq 1 0 0
-> 172.16.1.1:http Masq 1 256 0
-> 172.16.1.2:http Masq 1 0 0
-> scottstuff.net:http Masq 1 0 0
Exactly which backend gets the traffic varies from time to time, but it’s almost always a single backend. Changing the LB algorithm in VyOS doesn’t seem to matter.
However, manually changing the algorithm via ipvsadm and then changing it back makes future traffic balance correctly:
# ipvsadm -E -t 50.106.9.46:8080 -s rr
# ipvsadm -E -t 50.106.9.46:8080 -s wrr
... run test ...
-> 172.16.0.1:http Masq 1 42 0
-> 172.16.0.2:http Masq 1 43 0
-> 172.16.1.1:http Masq 1 43 256
-> 172.16.1.2:http Masq 1 42 0
-> scottstuff.net:http Masq 1 43 0
I saw the same behavior with a nightly build from July and just upgraded, but still see the same basic problem even with the newest nightly.
