High CPU usage on 2026.04.10-0031-rolling
After upgrading to 2026.04.10-0031-rolling, I started seeing a constantly running python process consuming around 6 - 50% CPU, even when the system is idle.
Problem
The process continuously executes:
/bin/cli-shell-api --show-active-only showConfig interfaces
This happens in a loop and does not stop.
Debugging
I attached strace to the process and observed repeated executions:
strace: Process 6134 attached
strace: Process 16362 attached
[pid 16362] execve("/bin/cli-shell-api", ["/bin/cli-shell-api", "--show-active-only", "showConfig", "interfaces"], ...) = 0
[pid 16362] +++ exited with 0 +++
--- SIGCHLD ...
strace: Process 16363 attached
[pid 16363] execve("/bin/cli-shell-api", ["/bin/cli-shell-api", "--show-active-only", "showConfig", "interfaces"], ...) = 0
[pid 16363] +++ exited with 0 +++
--- SIGCHLD ...
... repeats continuously
It looks like something is polling interface configuration in a tight loop.
Configuration note
This is a very minimal setup — I am only using BGP (no complex services or additional features configured).
Expected behavior
The system should not continuously call cli-shell-api when there are no configuration changes, and CPU usage should remain low.
Actual behavior
A python process continuously spawns cli-shell-api, causing constant CPU load (~6 - 50%).
Regression
After rolling back to 2026.04.01-0034-rolling, the issue is no longer reproducible:
  • CPU usage returns to normal
  • Looping behavior disappears
Conclusion
This appears to be a regression introduced in 2026.04.10-0031-rolling, possibly related to a component repeatedly querying interface configuration.
Thanks for reporting this. I believe I see the issue, and will update this thread with the vyos.dev task link, once it is created.
Hi @Boris,
thanks for reporting. This will be tracked via ⚓ T8486 vyos-netlinkd causes high CPU usage
