Hostap build fail (remote git server issue)
vyos-build/scripts/package-build/hostap/package.toml refers to a currently nonworking git server at git://w1.fi/srv/git/hostap.git. I think it might be better to use the https URL as they suggest which does work.
Also, the build_cmd tries to call the nonexisting program “y” which I suspect was meant to be the ancient “yes” utility. The build is getting away with it because nothing is actually expecting any “y” responses for now, but it may as well get fixed.
Trivial patch below.
hostap-package.toml.patch.txt (485 Bytes)
I have created a bug report ⚓ T7993 Hostap build fail
Would you like to create a PR to fix it?
Thanks for the report! I made a PR: hostap: T7993: fix the git source URL by dmbaturin · Pull Request #1067 · vyos/vyos-build · GitHub
