Hello members.
This is a document about driver development for VyOS.
1, build kernel module
http://vyos.net/wiki/Rebuild_VyOS_kernel_Step
Note: Please checkout proper kernel version.
2, Download driver source
Sample Driver
Download Intel Drivers and Software
http://downloadmirror.intel.com/15817/eng/e1000e-3.0.4.tar.gz
Is this driver for Intel 82579V ? I found this issue so I tried this driver.
http://bugzilla.vyos.net/show_bug.cgi?id=141
3, build
tar xvfz ./e1000e-3.0.4.tar.gz
cd e1000e-3.0.4/src
export KSRC=/path/to/build-iso/pkgs/linux-image/debian/build/build-amd64-none-amd64-vyos
make
You can find new e1000e.ko binary on current directory.
And replace e1000e.ko on VyOS
Maybe work well. I haven’t test environment for this driver.
TODO
Hiroyuki Sato
https://github.com/hiroyuki-sato/vyos-e1000e-driver
I succeed to create package, however I can’t install properly yet.
Problem
Currently I removed original e1000e.ko module in preinst,
Then install new one.
But when I execute make iso on build-iso module
I got the following error
W: mdadm: unchecked configuration file: /etc/mdadm/mdadm.conf
W: mdadm: please read /usr/share/doc/mdadm/README.upgrading-2.5.3.gz .
W: mkconf: MD subsystem is not loaded, thus I cannot scan for arrays.
W: mdadm: failed to auto-generate temporary mdadm.conf file.
W: mdadm: no configuration file available.
xargs: aptitude: exited with status 255; aborting
E: chroot build failed
I also filed issue list
https://github.com/hiroyuki-sato/vyos-e1000e-driver/issues/1
Does anyone have an idea for avoid this error?
My alternative idea is to replace e1000e driver in linux-image.
But I think it is hard to maintain.
Best regards
Hiroyuki Sato
