i use VyOs 1.1.8 about 3 months for wan load balancer with per packet classifier.
But some dest address prevent we dynamically ip public,
when i try to use another router without load balance, it reach dest address.
So I wanna try to bypass some dest address from load balancer.
Hello, @adew07!
Of course, you can use exclude option or destination address with inversion. In VyOS 1.2:
vyos@vyos# set load-balancing wan rule 10
Possible completions:
description Description for this rule
> destination Destination
exclude Exclude packets matching this rule from wan load balance <=== you need this ===
failover Enable failover for packets matching this rule from wan load balance
inbound-interface
Inbound interface name (e.g., "eth0") [REQUIRED]
+> interface Interface name [REQUIRED]
> limit Enable packet limit for this rule
per-packet-balancing
Option to match traffic per-packet instead of the default, per-flow
protocol Protocol to match
> source Source information
vyos@vyos# set load-balancing wan rule 10 destination address
<x.x.x.x> IP address to match
<x.x.x.x/x> Subnet to match
<x.x.x.x>-<x.x.x.x>
IP range to match
!<x.x.x.x> Match everything except the specified address <=== or this ===
!<x.x.x.x/x> Match everything except the specified subnet
!<x.x.x.x>-<x.x.x.x>
Match everything except the specified range
