I want to build vyos iso.
As I’am in Chinese mainland, network to deb.debian.org is poor.
So I want to change mirrors but it didn’t work well. Is there anyone can help me? thanks!
- I changed mirrors in configure:
./configure --debian-mirror http://ftp.cn.debian.org/debian/ --architecture amd64 --build-by "[email protected]" --debian-security-mirror http://ftp.cn.debian.org/debian/ --pbuilder-debian-mirror http://ftp.cn.debian.org/debian/
Loading data/defaults.json
- I checked the build/build-config.json:
"architecture": "amd64",
"bootloaders": "syslinux,grub-efi",
"build_by": "[email protected]",
"build_comment": "",
"build_dir": "build",
"build_type": "development",
"custom_apt_entry": [
"deb [arch=amd64] https://repo.saltproject.io/py3/debian/11/amd64/3004 bullseye main",
"deb [arch=amd64] http://repo.powerdns.com/debian bullseye-rec-45 main",
"deb [arch=amd64] https://repos.influxdata.com/debian bullseye stable"
"custom_apt_key": null,
"custom_package": [],
"debian_mirror": "http://ftp.cn.debian.org/debian/",
"debian_security_mirror": "http://ftp.cn.debian.org/debian/",
"debug": false,
"distribution": "bullseye",
"kernel_flavor": "amd64-vyos",
"kernel_version": "5.10.127",
"pbuilder_config": "build/pbuilderrc",
"pbuilder_debian_mirror": "http://ftp.cn.debian.org/debian/",
"release_train": "sagitta",
"version": null,
"vyos_branch": "current",
"vyos_mirror": "http://dev.packages.vyos.net/repositories/current"
- It speed up at first. However I noticed output like this:
Get:2 http://security.debian.org/debian-security buster/updates InRelease [65.4 kB]
Hit:1 http://mirrors.ustc.edu.cn/debian bullseye InRelease
Get:3 http://deb.debian.org/debian buster InRelease [122 kB]
Get:4 http://mirrors.ustc.edu.cn/debian bullseye-updates InRelease [39.4 kB]
Get:5 http://mirrors.ustc.edu.cn/debian bullseye-backports InRelease [44.2 kB]
Get:6 http://mirrors.ustc.edu.cn/debian bullseye/non-free Sources [80.6 kB]
Get:7 http://mirrors.ustc.edu.cn/debian bullseye/contrib Sources [43.0 kB]
Get:8 http://mirrors.ustc.edu.cn/debian bullseye/main Sources [8627 kB]
Get:9 https://repos.influxdata.com/debian bullseye InRelease [4739 B]
Get:10 http://security.debian.org/debian-security buster/updates/main amd64 Packages [329 kB]
Get:11 https://repo.saltproject.io/py3/debian/11/amd64/3004 bullseye InRelease [2850 B]
Get:12 http://dev.packages.vyos.net/repositories/current current InRelease [4189 B]
Get:13 https://repos.influxdata.com/debian bullseye/stable amd64 Packages [1259 B]
Get:14 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Get:15 https://repo.saltproject.io/py3/debian/11/amd64/3004 bullseye/main amd64 Packages [2917 B]
Get:16 http://repo.powerdns.com/debian bullseye-rec-45 InRelease [1798 B]
Get:17 http://dev.packages.vyos.net/repositories/current current/main amd64 Packages [43.4 kB]
Get:18 http://repo.powerdns.com/debian bullseye-rec-45/main amd64 Packages [842 B]
Get:19 http://deb.debian.org/debian buster/main amd64 Packages [7911 kB]
Get:20 http://mirrors.ustc.edu.cn/debian bullseye/main Translation-en [6241 kB]
Get:21 http://mirrors.ustc.edu.cn/debian bullseye/contrib Translation-en [46.9 kB]
Get:22 http://mirrors.ustc.edu.cn/debian bullseye/non-free Translation-en [91.3 kB]
Get:23 http://mirrors.ustc.edu.cn/debian bullseye-updates/main Sources [1868 B]
Get:24 http://mirrors.ustc.edu.cn/debian bullseye-updates/main amd64 Packages [2592 B]
Get:25 http://mirrors.ustc.edu.cn/debian bullseye-updates/main Translation-en [2343 B]
Get:26 http://mirrors.ustc.edu.cn/debian bullseye-backports/main Sources [289 kB]
Get:27 http://mirrors.ustc.edu.cn/debian bullseye-backports/non-free Sources [3548 B]
Get:28 http://mirrors.ustc.edu.cn/debian bullseye-backports/contrib Sources [2556 B]
Get:29 http://mirrors.ustc.edu.cn/debian bullseye-backports/main amd64 Packages [304 kB]
Get:30 http://mirrors.ustc.edu.cn/debian bullseye-backports/main Translation-en [234 kB]
Get:31 http://mirrors.ustc.edu.cn/debian bullseye-backports/contrib amd64 Packages [4704 B]
Get:32 http://mirrors.ustc.edu.cn/debian bullseye-backports/contrib Translation-en [4196 B]
Get:33 http://mirrors.ustc.edu.cn/debian bullseye-backports/non-free amd64 Packages [11.0 kB]
Get:34 http://mirrors.ustc.edu.cn/debian bullseye-backports/non-free Translation-en [8252 B]
Get:35 http://security.debian.org/debian-security buster/updates/main Translation-en [178 kB]
Get:36 http://security.debian.org/debian-security buster/updates/non-free amd64 Packages [556 B]
Get:37 http://security.debian.org/debian-security buster/updates/non-free Translation-en [344 B]
Get:38 http://deb.debian.org/debian buster/main Translation-en [5969 kB]
Ign:38 http://deb.debian.org/debian buster/main Translation-en
Get:39 http://deb.debian.org/debian buster/non-free amd64 Packages [87.7 kB]
Get:40 http://deb.debian.org/debian buster/non-free Translation-en [88.8 kB]
Get:41 http://deb.debian.org/debian buster-updates/main amd64 Packages [8788 B]
Get:42 http://deb.debian.org/debian buster-updates/main Translation-en [6915 B]
Err:38 http://deb.debian.org/debian buster/main Translation-en
Connection timed out [IP: 146.75.114.132 80]
Fetched 25.0 MB in 8min 52s (47.0 kB/s)
Reading package lists...
E: Failed to fetch http://deb.debian.org/debian/dists/buster/main/i18n/Translation-en Connection timed out [IP: 146.75.114.132 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
P: Saving caches...
Building dependency tree...
make: *** [Makefile:32: iso] Error 1
