How to clear ip bgp? [solved]
Hi there,
The first time I used Vyos, I tried to use the command like I use in EdgeRouter: clear ip bgp external soft out.
Seeing this command doesn’t exist, I searched for correct one.
So, I tried to use the: reset ip bgp external soft out
But it appears that this command is not doing what it need to be done.
The routes are not updated and the only way to do the job is resetting the peer using: reset
Even with the “soft-reconfiguration inbound” inside the BGP peer…
What Do I need to do?
Thanks for any help!
The command is: reset ip bgp * soft
This one do the soft reset.
Thx
