hello guys
how i can stop spoofing ?
i do not want use rp or urp filter for close spoofing i want to close this with firewall rules
can someone tell me how i can do this
my wan interface → eth1
my lan interface → eth2
hello guys
Do you have bgp and own block of ip addresses?
It that Spoofing from wan or lan network?
You can drop traffic on wan interface which match source “lan” network as you expected it from Lan.
If it just random source ip addresses there are no option to block it on any vendor equipment.
yes i have bgp and own block of ip addresses
is that spoofing outgoing from my network → lan
i want drop out spoof connections
i made this configuration is correct ?
set interfaces ethernet eth3 firewall in name LAN-OUT
set interfaces ethernet eth3 firewall out name LAN-IN
set firewall group address-group LAN address prefix1/24
set firewall group address-group LAN address prefix2/24
set firewall group address-group LAN address prefix3/24
////////////////////////// LAN-IN ////////////////////////
#drop
set firewall name LAN-IN default-action drop
#tcp
set firewall name LAN-IN rule 14 action accept
set firewall name LAN-IN rule 14 protocol tcp
#udp
set firewall name LAN-IN rule 15 action accept
set firewall name LAN-IN rule 15 protocol udp
////////////////////////// LAN-OUT ////////////////////////
#drop
set firewall name LAN-OUT default-action drop
#tcp
set firewall name LAN-OUT rule 14 action accept
set firewall name LAN-OUT rule 14 protocol tcp
set firewall name LAN-OUT rule 14 source group address-group LAN
#udp
set firewall name LAN-OUT rule 15 action accept
set firewall name LAN-OUT rule 15 protocol udp
set firewall name LAN-OUT rule 15 source group address-group LAN
