How to configure dhcpv6-pd
Hello community,
I have tried to make dhcpv6-server and advertise dhcpv6-pd. I share configuration:
FOR SERVIER
vyos@vyos-1# run show configuration commands | match eth1
set interfaces ethernet eth1 address ‘2001:db9:0101:3000::1/64’
set interfaces ethernet eth1 hw-id ‘08:00:27:31:6f:1c’
set interfaces ethernet eth1 ipv6 disable-forwarding
set service dhcpv6-server listen-interface ‘eth1’
set service dhcpv6-server shared-network-name VLAN30 interface ‘eth1’
set service dhcpv6-server shared-network-name VLAN30 subnet 2001:db9:0101:3000::/64 prefix-delegation prefix 2 001:db9:0101:3001:: delegated-length ‘64’
set service dhcpv6-server shared-network-name VLAN30 subnet 2001:db9:0101:3000::/64 prefix-delegation prefix 2 001:db9:0101:3001:: prefix-length ‘56’
set service dhcpv6-server shared-network-name VLAN30 subnet 2001:db9:0101:3000::/64 subnet-id ‘300’
CUSTOMER
vyos@cust-1-vyos# run show configuration commands | match eth1
set interfaces ethernet eth1 address ‘dhcpv6’
set interfaces ethernet eth1 dhcpv6-options pd 1 interface eth1
set interfaces ethernet eth1 dhcpv6-options pd 1 length ‘64’
set interfaces ethernet eth1 hw-id ‘08:00:27:a6:d0:a6’
set interfaces ethernet eth1 ipv6 address autoconf
vyos@cust-1-vyos# run show configuration commands | match eth2
set interfaces ethernet eth2 address ‘dhcpv6’
set interfaces ethernet eth2 hw-id ‘08:00:27:a0:4f:7d’
set interfaces ethernet eth2 ipv6 address autoconf
ON customer router, I don’t have any assigned ipv6. Please share experience or advice !
I suddendly have trouble getting my V6 to work too, i wonder if thats a change from a nightly.
My config didnt change but im not getting any replies.
Which version of vyos are you using?
Hi MartB,
My version is 1.5-rolling-202407280023, but I made some changes from yesterday.
set service router-advert interface eth1 default-preference ‘high’
set service router-advert interface eth1 name-server ‘2001:db9:0101:3000::1’
set service router-advert interface eth1 other-config-flag
set service router-advert interface eth1 prefix 2001:db9:101:3000::/64
This section is important to Notify customer device, router or whatever to use IPv6 “other-flag”, not only SLAAC
set service dhcpv6-server shared-network-name VLAN30 subnet 2001:db9:0101:3000::/52 prefix-delegation prefix 2001:db9:0101:3000:: delegated-length ‘64’
set service dhcpv6-server shared-network-name VLAN30 subnet 2001:db9:0101:3000::/52 prefix-delegation prefix 2001:db9:0101:3000:: prefix-length ‘64’
set service dhcpv6-server shared-network-name VLAN30 subnet 2001:db9:0101:3000::/52 subnet-id ‘30’
This section should initiate dhcpv6-pd for customer devices. But I don’t have luck with that one.
All documentation is missing an explanation how the configuration idea is structured and why developers decided on that approach.
Missing good examples, and it is a good idea to have case studies for every contributor who wants to share their own experience.
Best you, good luck
Hello community,
I can share configuration that working but make dhcpv6-pd from 56 to 64
set service dhcpv6-server shared-network-name NET1 subnet 2a01:4a40:101:3000::/56 interface ‘eth1’
set service dhcpv6-server shared-network-name NET1 subnet 2a01:4a40:101:3000::/56 option name-server ‘2a01:4a40:101:3000::1’
set service dhcpv6-server shared-network-name NET1 subnet 2a01:4a40:101:3000::/56 prefix-delegation prefix 2a01:4a40:101:3100:: delegated-length ‘64’
set service dhcpv6-server shared-network-name NET1 subnet 2a01:4a40:101:3000::/56 prefix-delegation prefix 2a01:4a40:101:3100:: prefix-length ‘56’
set service dhcpv6-server shared-network-name NET1 subnet 2a01:4a40:101:3000::/56 range 1 start ‘2a01:4a40:101:3000::100’
set service dhcpv6-server shared-network-name NET1 subnet 2a01:4a40:101:3000::/56 range 1 stop ‘2a01:4a40:101:3000::ffff:fff0’
set service dhcpv6-server shared-network-name NET1 subnet 2a01:4a40:101:3000::/56 subnet-id ‘1’
but when I try to make configuration from 52 to 64:
So IP range in that case should be 2a01:4a40:101:3000:: to 2a01:4a40:101:3fff::
and kea-dhcpv6 has unable to start with that error:
“Invalid Pool6 address boundaries: 2a01:4a40:101:3001:: is not the first address in prefix: 2a01:4a40:101:3000::/52”
kea-dhcp6-server.service - Kea IPv6 DHCP daemon
Loaded: loaded (/lib/systemd/system/kea-dhcp6-server.service; disabled; preset: enabled)
Drop-In: /etc/systemd/system/kea-dhcp6-server.service.d
└─override.conf
Active: failed (Result: exit-code) since Thu 2024-08-08 14:57:39 UTC; 8s ago
Any suggestions ?
