hello everyone,
i currently work with DMVPN with IPSEC, its perfectly work. but it is posible to add one more hub for redundancy purposed?
thank you
hello everyone,
thank you
Hmm…How many spokes you have? And what are those cisco? Mind sharing the config of Hub and spoke?
Maybe you can to do it with VRRP but
How you will synchronise IPSec sessions? There are no any tools for it.
So after change server you have to wait when all spokes “reconnect”/rekeying to establish new keys/SA’s with new hub.
yeah maybe i will go with VRRP
btw, how about multiHUB DMVPN single hub like Dynamic Multipoint IPsec VPNs (Using Multipoint GRE/NHRP to Scale IPsec VPNs) - Cisco. did VYOS support this method? i tried it, but no luck
HUB 1
set interfaces tunnel tun100 address '10.10.0.1/24'
set interfaces tunnel tun100 mtu '8024'
set interfaces tunnel tun100 encapsulation 'gre'
set interfaces tunnel tun100 source-address 220.110.134.1
set interfaces tunnel tun100 multicast 'enable'
set interfaces tunnel tun100 parameters ip key '1'
set protocols nhrp tunnel tun100 cisco-authentication 'xxx'
set protocols nhrp tunnel tun100 holding-time '300'
set protocols nhrp tunnel tun100 multicast 'dynamic'
set protocols nhrp tunnel tun100 redirect
set protocols nhrp tunnel tun100 shortcut
set vpn ipsec esp-group ESP-HUB compression 'disable'
set vpn ipsec esp-group ESP-HUB lifetime '1800'
set vpn ipsec esp-group ESP-HUB mode 'transport'
set vpn ipsec esp-group ESP-HUB pfs 'dh-group2'
set vpn ipsec esp-group ESP-HUB proposal 1 encryption 'aes256'
set vpn ipsec esp-group ESP-HUB proposal 1 hash 'sha1'
set vpn ipsec esp-group ESP-HUB proposal 2 encryption '3des'
set vpn ipsec esp-group ESP-HUB proposal 2 hash 'md5'
set vpn ipsec ike-group IKE-HUB ikev2-reauth 'no'
set vpn ipsec ike-group IKE-HUB key-exchange 'ikev1'
set vpn ipsec ike-group IKE-HUB lifetime '3600'
set vpn ipsec ike-group IKE-HUB proposal 1 dh-group '2'
set vpn ipsec ike-group IKE-HUB proposal 1 encryption 'aes256'
set vpn ipsec ike-group IKE-HUB proposal 1 hash 'sha1'
set vpn ipsec ike-group IKE-HUB proposal 2 dh-group '2'
set vpn ipsec ike-group IKE-HUB proposal 2 encryption 'aes128'
set vpn ipsec ike-group IKE-HUB proposal 2 hash 'sha1'
set vpn ipsec profile NHRPVPN authentication mode 'pre-shared-secret'
set vpn ipsec profile NHRPVPN authentication pre-shared-secret 'xxx'
set vpn ipsec profile NHRPVPN bind tunnel 'tun100'
set vpn ipsec profile NHRPVPN esp-group 'ESP-HUB'
set vpn ipsec profile NHRPVPN ike-group 'IKE-HUB'
HUB2
set interfaces tunnel tun100 address '10.10.0.2/24'
set interfaces tunnel tun100 source-address 220.110.134.2
set protocols nhrp tunnel tun100 cisco-authentication 'xxxx'
set vpn ipsec profile NHRPVPN authentication pre-shared-secret 'xxxx'
commit
Spoke
set interfaces tunnel tun100 address '10.10.0.3/24'
set interfaces tunnel tun100 source-address 220.110.134.3
set protocols nhrp tunnel tun100 map 10.10.0.1/24 nbma-address '220.110.134.1'
set protocols nhrp tunnel tun100 map 10.10.0.1/24 register
set protocols nhrp tunnel tun100 map 10.10.0.2/24 nbma-address '220.110.134.2'
set protocols nhrp tunnel tun100 map 10.10.0.2/24 register
set protocols nhrp tunnel tun100 multicast 'nhs'
set vpn ipsec ike-group IKE-HUB close-action 'none'
Fair warning, I have not tried DMVPN on VyOS yet but I have ran DMVPN extensively on Cisco. That said, have you tried a dual-hub / dual-dmvpn design instead?
