Vyos ver. 1.1.8
When in configuration mode, you can easily disable a NAT rule by using the “disabled” argument. E.g.:
set destination nat rule 10 disabled
But how to enable it again ?
Vyos ver. 1.1.8
delete destination nat rule 10 disabled
commit
save
So there is no way to enable the rule again but to delete ad re-create (?)
You’re only deleting the ‘disabled’ component, not the entire rule
Allright
Thank you
