How to enable ssh passowrd authentication?
Hello, I am using 1.4 rolling version.
I found ssh login by password is disabled always.
This is my ssh configure:
vyos@vyos# show service ssh
 port 22
vyos@vyos#
But I found ssh running config:
vyos@vyos# cat /var/run/sshd/sshd_config | grep PasswordAuthentication
PasswordAuthentication no
vyos@vyos#
I have tried following steps but still not work!
vyos@vyos#
vyos@vyos# set service ssh disable-password-authentication
vyos@vyos# commit
vyos@vyos#
vyos@vyos# delete service ssh disable-password-authentication
vyos@vyos# commit
vyos@vyos#
Hi @ackema , I can not confirm that ssh password login does not work on the latest 1.4 rolling even with this param PasswordAuthentication no in /run/sshd/sshd_config.
When I set set service ssh disable-password-authentication my laptop CLI return
MacBook-Pro-Dmitriy:~ dmitriy$ ssh vyos@192.0.2.1
vyos@192.0.2.1: Permission denied (publickey).
After delete this from my lab VyOS router
vyos@vyos# commit
I can log in from my laptop to this router
Password:
Welcome to VyOS!
Check out project news at https://blog.vyos.io
and feel free to report bugs at https://phabricator.vyos.net
You can change this banner using "set system login banner post-login" command.
VyOS is a free software distribution that includes multiple components,
you can check individual component licenses under /usr/share/doc/*/copyright
Last login: Fri Dec  9 07:39:00 2022 from x.x.x.x
vyos@vyos:~$
Thanks!
when you exec “delete service ssh disable-password-authentication” and “commit”, what’s the value of param PasswordAuthentication in /run/sshd/sshd_config?
The values is still no
vyos@vyos# cat /run/sshd/sshd_config | grep PasswordAuthentication
Could you please describe which behaviors do you wait?
Thanks.
I want to login vyos via ssh with password instead of public-key.
If PasswordAuthentication is no, why can you login with password?
refers: sshd_config(5)
	     Specifies whether password	authentication is allowed.  See	also
	     UsePAM.  The default is no.
Following is my sshd_config
### Autogenerated by ssh.py ###
# https://linux.die.net/man/5/sshd_config
# Non-configurable defaults
Protocol 2
HostKey /etc/ssh/ssh_host_rsa_key
HostKey /etc/ssh/ssh_host_dsa_key
HostKey /etc/ssh/ssh_host_ecdsa_key
HostKey /etc/ssh/ssh_host_ed25519_key
SyslogFacility AUTH
LoginGraceTime 120
StrictModes yes
PubkeyAuthentication yes
IgnoreRhosts yes
HostbasedAuthentication no
PermitEmptyPasswords no
X11Forwarding yes
X11DisplayOffset 10
PrintMotd no
PrintLastLog yes
TCPKeepAlive yes
Banner /etc/issue.net
Subsystem sftp /usr/lib/openssh/sftp-server
UsePAM yes
PermitRootLogin no
PidFile /run/sshd/sshd.pid
AddressFamily any
DebianBanner no
# User configurable section
# Look up remote host name and check that the resolved host name for the remote IP
# address maps back to the very same IP address.
UseDNS yes
# Specifies the port number that sshd(8) listens on
Port 22
# Gives the verbosity level that is used when logging messages from sshd
LogLevel INFO
# Specifies whether password authentication is allowed
ChallengeResponseAuthentication yes
vyos@vyos#
and openssh-server version info:
root@vyos:/home/vyos# apt info openssh-server
Package: openssh-server
Version: 1:8.4p1-5+deb11u1
Status: install ok installed
Priority: optional
Is there any thing wroing?
disable-password-authentication param add ChallengeResponseAuthentication to config
From man
Specifies whether challenge-response authentication is allowed (e.g. via PAM or though authentication styles supported in login.conf(5)) The default is ''yes''.
It does not work for you when key auth configured for user?
Sorry, I found the reason.
If I use windows cmd: ssh vyos@192.168.x.y, it works like this:
However if I use Xshell 7, it pop-up a prompt box like this:
It seems password authentication is disabled, but Keyboard Interactive authentication is allowed.
Thanks again!
By the way, if I disable passord authentication, keyboard-interactive authentication is disabled
vyos@vyos# commit
vyos@vyos#
