When I clone the build-iso.git, pkgs/ subdirectories are empty??
git clone https://github.com/vyos/buid-iso.git
when I run make iso ,failed.
anyone can help me? I just want build iso from source code,help
http://www.vyos.net → howto build an ISO image
brings you to:
Thanks
But I not find any source code through this method.
I want build iso by source code ,yes, I is a green hand,can you tell me how to build iso by source code ,STEP BY STEP.
I find very good project,opennhrp-0.14.1, and i want put it in vyos.
Thank you .
The page I pointed you to,
explains : step-by-step
how to produce an ISO image in the end, from scratch.
Maybe you also take a look at this tiny howto.
Pretty easy and nearly just copy&paste ![]()
Builds an ISO in quite a few minutes.
