Hi VyOS,
How to let how to let 2 pppoe wan load-balancing work with policy base routing?
When i setup 2 pppoe wan loadbalancing with PBR settings on vyos 1.5 rolling version. the PBR stop working anymore. How to let these 2 functions work together?
AFAIK, the WLB and PBR functions can’t be used together. This is because WLB creates special routing tables that PBR can’t see.
There is a workaround that uses failover PBR with scripting as an alternate approach to WLB for dual dynamic nexthop WANs, for example see https://forum.vyos.io/t/pbr-rules-not-working-with-failover-on-dhcp-wan/
