I want to make iso with our own deb package(e.g. jctest.deb).
As documents said:
https://docs.vyos.io/en/latest/contributing/build-vyos.html
Building an ISO with any customized package is in no way different then building a regular (customized or not) ISO image. Simply place your modified *.deb package inside the packages folder within vyos-build. The build process will then pickup your custom package and integrate it into your ISO.
I place jctest.deb in vyos-build/packages/ and then make iso.
However, jctest is not included in vyos—xx—.iso.
What should I do to make iso with my own deb package?
Thanks.
