How to make lan as the default gateway and make static routing for wan works
Hi, All
I met an issue that I need LAN as the gateway ,but wan was not working. Here is my configuration:
vpn# run show configuration | strip-private
firewall {
    all-ping enable
    broadcast-ping disable
    config-trap disablessh
    ipv6-src-route disable
    ip-src-route disable
    log-martians enable
    send-redirects enable
    source-validation disable
    syn-cookies enable
        address xxx.xxx.74.61/29
        duplex auto
        smp-affinity auto
        speed auto
        address xxx.xxx.0.121/22
        duplex auto
        smp-affinity auto
        speed auto
    loopback lo {
nat {
        rule 120 {
            outbound-interface eth1
                address xxx.xxx.255.0/24
            translation {
                address masquerade
protocols {
    static {
        route xxx.xxx.0.0/0 {
            next-hop xxx.xxx.0.252 {
        route xxx.xxx.74.56/29 {
            next-hop xxx.xxx.74.57 {
service {
    ssh {
        port 22
system {
    acceleration {
    config-management {
        commit-revisions 100
    console {
        device ttyS0 {
            speed 9600
    domain-name xxxxxx
    host-name xxxxxx
    login {
        user xxxxxx {
            authentication {
                encrypted-password xxxxxx
                plaintext-password xxxxxx
                public-keys xxxx@xxx.xxx {
                    key xxxxxx
                    type ssh-rsa
            level admin
    name-server xxx.xxx.0.8
    ntp {
        server xxxxx.tld {
        server xxxxx.tld {
        server xxxxx.tld {
    syslog {
        global {
            facility all {
                level info
            facility protocols {
                level debug
vpn {
    ipsec {
        ipsec-interfaces {
            interface eth0
        nat-networks {
            allowed-network xxx.xxx.0.0/0 {
        nat-traversal enable
    l2tp {
        remote-access {
            authentication {
                mode radius
                radius {
                    server xxxxx.tld {
                        key xxxxxx
            client-ip-pool {
                start xxx.xxx.255.2
                stop xxx.xxx.255.254
            dns-servers {
                server-1 xxx.xxx.0.8
            idle 1800
            ipsec-settings {
                authentication {
                    mode pre-shared-secret
                    pre-shared-secret xxxxxx
                ike-lifetime 3600
                lifetime 3600
            outside-address xxx.xxx.74.61
            outside-nexthop xxx.xxx.0.121
Hi @echowings .
eth0 - WAN
eth1 - LAN
That correct?
If you have a route on the interface (eth0 address xxx.xxx.74.61/29) as connected, then you don’t need to create an additional static route. Directly connected routes will be preferable then static or dynamic routes.
Example xxx.xxx.74.57 - your default gw for WAN network.
Without vpn, example if you need to connect from PC 5.5.5.5 to host xxx.xxx.74.61.
You need create route to PC host 5.5.5.5 via WAN interface.
set protocols static route 5.5.5.5/32 next-hop xxx.xxx.74.57
@viacheslav I tried but failed ,since vyos make the directly connected routing mertic is 0. so this routing policy will be never work.
xxx.xxx.74.57 it’s your WAN gw? Which routing policy? I don’t see it in your configuration.
Do you have access to internet via this gw without LAN ?
This policy is not working , it is inactived. after follow your suggestion. it is actived. but vyos has a highest priority policy for xxx.xxxx.74.56/29 routing to wan interface with C flag . So we will never make the manually routing policy works.
You don’t need this route as static, because it directly connected route to eth0.
You need some route via WAN, correct?
Which route should be routed through the WAN interface?
And provide routing information
show ip route
Please check my topology on the first post. I need manually setup wan address and gateway to make it can connect ISP A network. but i switch the default gateway to lan xxx.xxx.0.252 that make WAN disconnected since the wan network can not find the next-hop. At the same time vyos just make the interface as the default routing for wan network.
Hello @echowings, I reproduced this schema in our laboratory, and I think I have workaround.
On GW2 needs to add static route to l2tp client
set protocols static route 192.168.255.0/24 next-hop 10.0.0.2
And in VyOS-l2tp node add ip rule (not VyOS CLI command)
sudo ip rule add from 192.168.255.0/24 table 100
#and
set protocols static table 100 route 0.0.0.0/0 next-hop 10.0.0.1
ps:// Thanks @Viacheslav for idea
It works, Thanks your a tone!
sudo ip rule add from 172.20.0/24 table 100
# Then add the route table 100
set table 100 route 0.0.0.0/0 next-hop x.x.x.252
# To keep the command working after reboot ,we need add a booting script
vi /config/scripts/vyos-postconfig-bootup.script
#add the command in the script
Hi Sir,
I’m a new Vyos user. May I ask if this PBR only works with static route?
Can PBR routing table is using other than static route such as OSPF?
Looking forward for your advise.
One more thing. Can we use route-map to store the access list just like Cisco PBR?
Hi @zakwan, I think you can. Read at first Policy — VyOS 1.5.x (circinus) documentation
Please, explain detailed.
Hi @Dmitry ,
Currently I trying to create an environment with 4 vyos router with OSPF routing.
And i try to change routing using PBR but its not working probably because its not feasible with OSPF?
Below (Cisco) is the situation that I want to try on Vyos.
Below is Vyos design on my gns3:
Do you need PBR match protocol or match some rules in acl? Can you describe by steps what you need?
