This is my vyos router:
I want to redirect some packets with nft commands:
nft add table inet mangle
nft 'add chain inet mangle janusnat { type nat hook prerouting priority -130; }'
nft add inet mangle janusnat meta mark 2 tcp dport 80 counter redirect to 2061
If I configure source nat in vyos, nft’s redirections works
vyos@vyos# show protocols
static {
route 0.0.0.0/0 {
next-hop 10.10.193.1 {
vyos@vyos#
vyos@vyos# show nat
rule 1 {
outbound-interface eth0
address 0.0.0.0/0
translation {
address masquerade
However, if the vyos does not configure souce nat, packets will bypass my ruleset?
static {
route 0.0.0.0/0 {
vyos@vyos#
vyos@vyos# show nat
Configuration under specified path is empty
How can I make the nft ruleset do redirect without vyos’s source nat?
Thanks
