The problem with my first trial was that I hit this bug:
The “Packages” file in the Debian mirror needs to be sorted,
else the postinstall script of base-files pkg fails because /etc/passwd
does not exist. I use apt-ftparchive to create my mirror and it does not
sort. May be other tools do. Anyway the solution I chose is to add a
script to sort the packages alphabetically.
Show my procedures below. Usual disclaimer: use at your own risk.
No gaurantee it will work in your environment.
Based on:
Main changes:
- Create two repos instead of one.
- The Packages file for Debain packages is sorted alphabetically to avoid
base-passwd and base-files conflict during core packages install.
- apt-ftparchive conf files and update scripts in current work dir, not $HOME.
Requirements:
apt-utils
apache2 web server
basic terminal knowledge
In this tutorial I will use i386 architecture. If you are using any other, be sure to change i386 to your architecture code below.
First add a separate user. I used user ‘apt’.
Run these commands as root user
adduser apt --disabled-password (You can set password later if needed, or you can su to that user via terminal or console)
export APTUSER=/home/apt
mkdir $APTUSER/logs
mkdir -p $APTUSER/public_html/debian-oxnard/pool/main (directory to place debian packages)
mkdir -p $APTUSER/public_html/debian-oxnard/dists/squeeze/main/binary-i386
mkdir -p $APTUSER/public_html/vyatta-dev/oxnard/pool/main (directory to place Vyatta built packages)
mkdir -p $APTUSER/public_html/vyatta-dev/oxnard/dists/oxnard/main/binary-i386
touch $APTUSER/logs/access.log $APTUSER/logs/error.log (These two are used by apache web server)
Let’s create some files. Use your favourite editor
File $APTUSER/public_html/debian-oxnard/aptftp.conf
APT::FTPArchive::Release {
Origin "Debian";
Label "Debian";
Suite "stable";
Codename "squeeze";
Architectures "i386";
Components "main";
Description "Debian packages for oxnard build";
File $APTUSER/public_html/debian-oxnard/aptgenerate.conf
Dir::ArchiveDir ".";
Dir::CacheDir ".";
TreeDefault::Directory "pool/";
TreeDefault::SrcDirectory "pool/";
Default::Packages::Extensions ".deb";
Default::Packages::Compress ". gzip";
Default::Sources::Compress "gzip";
Default::Contents::Compress "gzip";
BinDirectory "dists/squeeze/main/binary-i386" {
Packages "dists/squeeze/main/binary-i386/Packages";
Contents "dists/squeeze/Contents-i386";
SrcPackages "dists/squeeze/main/source/Sources";
Tree "dists/squeeze" {
Sections "main";
File $APTUSER/public_html/debian-oxnard/update (script to update debian packages)
#!/bin/bash
INDEXFILE=`sed -n -e 's/^ *Packages "\(.*\)";/\1/p' aptgenerate.conf`
apt-ftparchive generate -c=aptftp.conf aptgenerate.conf
mv $INDEXFILE /tmp/Packages.$$
$HOME/sort_packages.pl /tmp/Packages.$$ > $INDEXFILE
gzip -c $INDEXFILE > ${INDEXFILE}.gz
rm -f /tmp/Packages.$$
apt-ftparchive release -c=aptftp.conf dists/squeeze > dists/squeeze/Release
rm -f dists/squeeze/Release.gpg
gpg -u <yourgpgkeyID> -bo dists/squeeze/Release.gpg dists/squeeze/Release
rm packages-i386.db
File $APTUSER/public_html/vyatta-dev/oxnard/aptftp_dev.conf
Origin "Vyatta";
Label "Vyatta";
Suite "unstable";
Codename "oxnard";
Components "main";
Description "Vyatta built packages for oxnard";
File $APTUSER/public_html/vyatta-dev/oxnard/aptgenerate_dev.conf
Dir::CacheDir ".";
BinDirectory "dists/oxnard/main/binary-i386" {
Packages "dists/oxnard/main/binary-i386/Packages";
Contents "dists/oxnard/Contents-i386";
SrcPackages "dists/oxnard/main/source/Sources";
Tree "dists/oxnard" {
Sections "main";
File $APTUSER/public_html/vyatta-dev/oxnard/update_dev (The packages update script)
NB: the Packages file in this repo does not need to be sorted.
#!/bin/bash
apt-ftparchive generate -c=aptftp_dev.conf aptgenerate_dev.conf
apt-ftparchive release -c=aptftp_dev.conf dists/oxnard > dists/oxnard/Release
rm -f dists/oxnard/Release.gpg
gpg -u <yourgpgkeyID> -bo dists/oxnard/Release.gpg dists/oxnard/Release
rm packages-i386.db
File $APTUSER/sort_packages.pl
#!/usr/bin/perl
use strict;
my $infile = $ARGV[0];
my $fh;
open($fh, "<", $infile) or die "open $infile fail $!\n";
my @lines = <$fh>;
close($fh);
my %h;
my $i = 0;
foreach (@lines) {
if (/^Package: (.*)/) {
$h{$1} = $i;
$i++;
my @pkglist = sort keys %h;
foreach my $name (@pkglist) {
printpkg($name);
sub printpkg
my $name = shift;
my $l;
my $j = $h{$name};
do {
$l = $lines[$j++];
print "$l";
} while (length($l) > 1);
Make the scripts executable:
chmod 755 $APTUSER/public_html/debian-oxnard/update
chmod 755 $APTUSER/public_html/vyatta-dev/oxnard/update_dev
chmod 755 $APTUSER/sort_packages.pl
And now change ownership of all files and directories created now to user apt
chown -R apt:apt $APTUSER
Note: These commands could also be run as normal user, but to avoid constant user switching I done it this way.
Now, let’s configure apache
ifconfig eth0 | grep ‘inet addr’
inet addr:192.168.1.253 Bcast:192.168.1.255 Mask:255.255.255.0
Since eth0 is my primary nic and 192.168.1.253 is my internal ip address, I will use it for configuring apache web server
Again, use your favourite text editor to edit/create these files
File /etc/apache2/ports.conf
NameVirtualHost 192.168.1.253 :80
Listen 80
File /etc/apache2/sites-available/apt
<VirtualHost 192.168.1.253 :80>
ServerAdmin yourname@email.com
DocumentRoot /home/apt/public_html
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /home/apt/public_html>
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Order allow,deny
Allow from all
</Directory>
CustomLog /home/apt/logs/access.log combined
ErrorLog /home/apt/logs/error.log
LogLevel warn
</VirtualHost>
Now run
a2ensite apt
invoke-rc.d apache2 restart
And try to access http://yourip/, in my case http://192.168.1.253 / You should see debian-oxnard and vyatta-dev.
Since there are no more commands to be run as root, let’s switch to apt user
su - apt
Generate GPG key for archive signing
gpg --gen-key (Use values you desire and be sure not to forget the passphrase)
gpg -K should give you output like this
gpg -K
/home/apt/.gnupg/secring.gpg
sec 2048R/yyyyyyyy 2014-04-02
uid Your Name your@email.com
ssb 2048R/F1B2F1B2 2014-04-02
Run
gpg --export yyyyyyyy > yourkey.gpg (This will be the public archive key)
At build time copy yourkey.gpg to build-iso/livecd/config.vyatta/chroot_sources/vyatta.chroot.gpg. Otherwise you will be asked this question:
Next put the real gpg key ID in $HOME/public_html/debian-oxnard/update, i.e. change
gpg -u -bao dists/squeeze/Release.gpg dists/squeeze/Release to
gpg -u yyyyyyyy -bao dists/squeeze/Release.gpg dists/squeeze/Release
And $HOME/public_html/vyatta-dev/oxnard/update_dev:
gpg -u -bao dists/oxnard/Release.gpg dists/oxnard/Release to
gpg -u yyyyyyyy -bao dists/oxnard/Release.gpg dists/oxnard/Release
Now, it is time to put your packages into $HOME/public_html/debian-oxnard/pool/main and $HOME/public_html/vyatta-dev/oxnard/pool/main.
After you done this, cd to ~/public_html/debian-oxnard and run
./update
Now repeat with the other repository, cd to ~/public_html/vyatta-dev/oxnard and run
./update_dev
Next, modify build-iso to use the local mirror.
You may want to check-in yourkey.gpg as livecd/config.vyatta/chroot_sources/vyatta.chroot.gpg permanently.
Then search livecd/mk.livecd.function for the 4 lines involving mirror layout. Change them as follows:
line 291:
LB_MIRROR_BINARY=http://192.168.1.253/debian-$branch
line 292:
LB_MIRROR_BOOTSTRAP=http://192.168.1.253/debian-$branch
line 295:
local dev_repo_root=http://192.168.1.253/vyatta-dev
line 314:
if [ ! -f vyatta.chroot ]; then
echo "deb $dev_repo_root/$branch $branch main" >vyatta.chroot
fi
