How to test openconnect in vyos 1.4
Dear Team
Iam using Openconnect feature on vyos 1.4 and iam using below commands from documents mentioned on vyos website.
run generate pki ca install i2k2
run generate pki certificate sign i2k2 install Devashish
set vpn openconnect authentication local-users username deva password ‘deva@12345’
set vpn openconnect authentication mode local ‘password’
set vpn openconnect http-security-headers
set vpn openconnect network-settings client-ip-settings subnet ‘10.34.1.0/24’
set vpn openconnect network-settings name-server ‘8.8.8.8’
set vpn openconnect network-settings name-server ‘8.8.4.4’
set vpn openconnect ssl ca-certificate ‘i2k2’
set vpn openconnect ssl certificate ‘Devashish’
Iam using it without 2FA . As per your documents only the above commands are mentioned i dont understand how my remote user get access the server behind the firewall , there is no option to mention public IP , no option for push route .
Now how i use it if i use openconnect client software.
Please let use know what iam missing
Please respond on the above concern as i need it to be configure ???
