JenBell
1
Hello Peoples,
Running vyOS in VMware workstation 10.
Q1. I shut down one of the interfaces, how to I re-enable / active / enable it again? There is no obvious command I can see.
Q2. I cannot set the MTU on any interface to larger than 1500. I can change it lower to 1000 fine.
First post…yay.
Thanks,
J
Just came cross the same issue,
you can simply use
delete interfaces ethernet ethX disable
to enable you concerned interface.
Hope it helps.
jkr
3
As with most JunOS alike systems, then you set a config, and in order to remove it again, you have to delete the config line.
The MTU part is sorta strange, as the help says:
Possible completions:
<68-9000> Maximum Transmission Unit (MTU)
Could it be your vmware that doesn’t allow the MTU change above 1500 ?
