IKE_SA_INIT no proposal chosen
Hello all,
I’m having trouble setting up a site-to-site connection like this between two vyos installations.
One is running in my lab called “central” and one is running in the oracle cloud called “ingress”.
I have double and triple checked the configuration but I cannot get past IKE_SA_INIT.
“Central” is behind a NAT without a static address and is initiating the connection, “Ingess” is probably also behind a NAT but has a static IP courtesy of Oracle.
Ingress config:
vincent@ingress# show vpn
 ipsec {
     esp-group common {
         pfs dh-group19
         proposal 1 {
             encryption aes128
             hash sha1
         proposal 2 {
             encryption aes256gcm128
             hash sha256
     ike-group commonIKE {
         key-exchange ikev2
         proposal 1 {
             dh-group 2
             encryption aes128
             hash sha1
         proposal 2 {
             dh-group 19
             hash sha256
     interface eth0
     log {
         level 2
         subsystem ike
     site-to-site {
         peer central {
             authentication {
                 local-id ingress
                 mode rsa
                 remote-id central
                 rsa {
                     local-key ipsec-ingress
                     remote-key ipsec-central
             connection-type respond
             default-esp-group common
             ike-group commonIKE
             local-address 138.2.151.6
             tunnel 1 {
                 local {
                     prefix 192.168.250.2/32
                 remote {
                     prefix 192.168.250.1/32
Central config:
vincent@central# show vpn
 ipsec {
     esp-group common {
         pfs dh-group19
         proposal 1 {
             encryption aes128
             hash sha1
         proposal 2 {
             hash sha256
         key-exchange ikev2
         proposal 1 {
             dh-group 2
             encryption aes128
             hash sha1
         proposal 2 {
             dh-group 19
             hash sha256
     interface eth0
     site-to-site {
         peer ingress {
             authentication {
                 local-id central
                 mode rsa
                 remote-id ingress
                 rsa {
                     local-key ipsec-central
                     remote-key ipsec-ingress
             connection-type initiate
             ike-group commonIKE
             local-address any
             remote-address 138.2.151.6
             tunnel 1 {
                 local {
                 remote {
This is the output of the log on the “Ingress”/Responder site:
vincent@ingress:~$ sudo swanctl --log
08[NET] received packet: from 138.199.18.65[10588] to 10.0.0.169[500] (372 bytes)
08[ENC] parsed IKE_SA_INIT request 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) N(FRAG_SUP) N(HASH_ALG) N(REDIR_SUP) ]
08[IKE] no IKE config found for 10.0.0.169...138.199.18.65, sending NO_PROPOSAL_CHOSEN
08[ENC] generating IKE_SA_INIT response 0 [ N(NO_PROP) ]
08[NET] sending packet: from 10.0.0.169[500] to 138.199.18.65[10588] (36 bytes)
As you can see I’ve tried adding different proposals from the docs to both IKE and ESP groups but that didn’t help. At this point I assume it has something to do with the NAT but I think that should be an issue because I configured matching IDs in the authentication section and use RSA like in the docs, no?
Edit: version info is probably useful too
Version:          VyOS 1.5-rolling-202310240118
Release train:    current
Built on:         Tue 24 Oct 2023 02:41 UTC
Build UUID:       66471dfc-8348-4dbf-953e-133854c539ff
Build commit ID:  142e8770563716
Architecture:     x86_64
System type:      KVM guest
Hardware vendor:  QEMU
Hardware model:   Standard PC (i440FX + PIIX, 1996)
Hardware S/N:
Hardware UUID:    df3bd66b-a30a-42e2-a824-57439af15abb
I’ve tried scouring the internet but the issue seems to usually be solved by just matching the proposals which I have done.
Any help is appreciated.
You may need to specify local-address in your site-to site config
set vpn ipsec site-to-site peer central local-address '10.0.0.169'   # IP address of interface eth0
That did it, thank you very much.
