IKEv2 Remote Access IPv6 not working
Hi everyone,
Been running IKEv2 RA over IPV4 with 0 problems, but want to implement IPv6 access.
Current RA routes all traffic through the VyOS instance, which is what I want
OS: VyOS 1.5-rolling-202311090023
IPSEC IKEv2 Config
NOTE: Firewall is all on default-action: accept
Configuration
firewall {
    ipv4 {
        forward {
            filter {
                default-action accept
                rule 1 {
                    action accept
                    state {
                        established enable
                rule 2 {
                    action accept
                    state {
                        invalid enable
        input {
            filter {
                rule 1 {
                    action accept
                    state {
                        established enable
                rule 2 {
                    action accept
                    state {
                        invalid enable
                rule 3 {
                    action accept
                    destination {
                        port 500,4500
                    inbound-interface {
                        name eth1
                    log enable
                    protocol tcp_udp
                rule 4 {
                    action accept
                    destination {
                        port 22
                    log enable
                    protocol tcp
                        group {
                            network-group LAN-Addresses
                rule 5 {
                    action accept
                    destination {
                        port 32400
                    inbound-interface {
                        name eth1
                    log enable
                    protocol tcp_udp
                rule 6 {
                    action accept
                    destination {
                        port 25565
                    inbound-interface {
                        name eth1
                    log enable
                    protocol tcp_udp
                rule 9 {
                    action accept
                    destination {
                        port 53
                    log enable
                    protocol tcp_udp
                        group {
                rule 10 {
                    action accept
                    destination {
                        port 161
                    log enable
                    protocol udp
                        group {
                rule 11 {
                    action accept
                    destination {
                        port 123
                    log enable
                    protocol udp
                        group {
        output {
            filter {
                rule 1 {
                    action accept
                    state {
                        established enable
                rule 2 {
                    action accept
                    state {
                        invalid enable
    ipv6 {
        forward {
            filter {
                enable-default-log
        input {
            filter {
                enable-default-log
        output {
            filter {
                enable-default-log
nat {
        rule 9 {
            destination {
                group {
            exclude
            outbound-interface {
                name eth1
                address 10.0.10.0/24
        rule 15 {
                name eth1
            translation {
                address masquerade
vpn {
    ipsec {
        esp-group RemoteAccessESP {
            proposal 1 {
                encryption aes256gcm128
                hash sha256
        ike-group RemoteAccessIKE {
            key-exchange ikev2
            proposal 1 {
                dh-group 14
                encryption aes256ctr
                hash sha256
            proposal 2 {
                dh-group 14
                hash sha256
            proposal 3 {
                dh-group 28
                encryption aes256
                hash sha256
            proposal 4 {
                dh-group 14
                encryption aes256
                hash sha256
        interface eth1
        options {
            virtual-ip
        remote-access {
            connection XX_MOBILE {
                authentication {
                    client-mode eap-mschapv2
                    local-id id
                    local-users {
                    server-mode x509
                    x509 {
                        ca-certificate ca
                        certificate certificatae
                local {
                    prefix 0.0.0.0/0
                    prefix ::/0
                pool MOBILE
            pool MOBILE {
                name-server 10.0.50.1
                prefix 10.0.10.0/24
            pool MOBILE-v6 {
                name-server fe80::268a:7ff:feb5:ee5f
                prefix FC00::/120
My site to site IPv6 works no problems.
When I connect to the RA over IPv6, nothing works on the client.
I can’t ping anything on IPv4, including the VyOS instance itself.
I’ve tested this on iOS (latest) and OSX (latest), but as soon as I connect back to the RA over IPv4, everything works perfectly again.
I’ve tried adding nat66 rules, but this still doesn’t work.
Maybe requires an addition configs IPv6 and the Neighbor Discovery Protocol :: strongSwan Documentation needs to play with it
Thanks @Viacheslav, I’ve looked at that documentation, and not sure how I would implement this in VyOS
To me this doesn’t explain that if NDP traffic isn’t excluded, why IPv4 traffic over IPv6 IKEv2 RA doesn’t work, as I would assume that IPv4 traffic should still be able to flow freely?
