As some who is familiar with linux system administration, i am used to using the “w” command to see who is logged in, uptime of the machine and load of the machine
ubnt@rtr-1:~$ w
19:00:18 up 41 days, 15:02, 0 users, load average: 0.15, 0.21, 0.18
USER TTY FROM LOGIN@ IDLE JCPU PCPU WHAT
ubnt@rtr-1:~$
To my surprise in the latest/greatest vyos 1.4 that is not the case.
w in vbash is somehow command completed to “wake-on-lan”
vyos@rtr-1:~$ w
Incomplete command: wake-on-lan
My request is that with command completion, if there is an existing command available in $PATH that should be executed before auto completion to a longer internal defined command.
So when i type “w” it would find /usr/bin/w and use that before autocompletion to “wake-on-lan”
For me VyOS is primarily an Internetworking Operating System with an underlying Linux OS and not the other way around. VyOS commands should be auto-complete prioritized over native OS commands.
I also agree with @Netboy3. The fact that Vyos is based on Debian isn’t really meant to be exposed to the user - you should feel you’re inside a router, not a Linux shell.
This is the same as how a Juniper Network’s router operates. It’s got FreeBSD roots and you can drop to a FreeBSD based shell if you need to, but by default you’re in the Juniper CLI which doesn’t even allow access to FreeBSD shell commands.
It’s understandable if you’ve come from a heavy Linux/Unix background what you’d want this, but I hope you understand why that’s not the choice the developers have made.
Cheers,
Tim
To me when you are in the regular or configuration mode then VyOS internal commands should be the first option.
But once I leave this environment and go for the OS shell by “sudo bash” then bash should use the linux path and linux commands first for command/tab-completion.
Welcome to VyOS
Linux vyatta 3.13.11-1-amd64-vyos #1 SMP Sat Nov 11 12:10:30 CET 2017 x86_64
Welcome to VyOS.
This system is open-source software. The exact distribution terms for
each module comprising the full system are described in the individual
files in /usr/share/doc/*/copyright.
Last login: Tue Jul 4 01:05:51 2023
vyos@vyos:~$ w
01:07:56 up 2 min, 2 users, load average: 0.01, 0.01, 0.01
vyos tty1 01:05 1:16 0.25s 0.14s vbash
vyos pts/0 orville 01:07 4.00s 0.07s 0.00s w
vyos@vyos:~$ show version
Version: VyOS 1.1.8
Description: VyOS 1.1.8 (helium)
Copyright: 2017 VyOS maintainers and contributors
Built by: [email protected]
Built on: Sat Nov 11 13:44:36 UTC 2017
Build ID: 1711111344-b483efc
System type: x86 64-bit
Boot via: image
Hypervisor: KVM
HW model: Standard PC (i440FX + PIIX, 1996)
HW S/N: Not Specified
HW UUID: 833E60F8-FDE9-9042-917D-B2732DB0F02D
Uptime: 01:08:13 up 2 min, 2 users, load average: 0.01, 0.01, 0.01
and here is where it changed:
Vyos 1.2.6
Version: VyOS 1.2.6
Release Train: crux
Built on: Wed 23 Sep 2020 13:21 UTC
Build UUID: 6c923469-b0f4-4ebc-9d1a-c364be3c7517
Build Commit ID: 706d01f247bb83
Architecture: x86_64
Boot via: installed image
System type: KVM guest
Hardware vendor: QEMU
Hardware S/N:
Hardware UUID: 6d032c5a-4e65-4614-99c2-70a38c162570
vyos@vyos:~$ w
unix commands like ip still work, that is not rerouted to some exclusive vyos command.
I would like to reconsider if the wake-on-lan command could/should be auto command completed to wa or something.
