Dear All,
I would like to know if it is possible to install infiniband drivers and OFED for debian on Vy-OS. I have to make a gateway between infiniband and 10 Gbit Ethernet networks.
Best regards,
Bibo
Dear All,
Best regards,
Bibo
I’m no vyos pro just started using it today but: Its debian 6 after all so just cross-compile the modules if the source is available. Binary should be fine as well as long as platform (x86, amd64) and debian 6 libraries are supported.
Ok.
I will try to install the MLNX_OFED_LINUX for debian6.0.10-x86_64. If it doesn´t work I will try to compile the OFED from openfabrics.
Has someone already done this?
Best regards,
