Install VyOS on Astaro UTM 9 hardware
Hi!
I have a old, decommissioned Astaro UTM box.
Can VyOS be installed on it without problems?
Hello @sinaowolabi,
Never have been an experience with this device. Do you have any specs for this HW?
Astaro typically ran on standard x86 hardware. I am guessing it will work fine.
Apologies for the late reply, I’ve been having to travel for work.
Specs (its an ASG 220) are here:
Processor Memory / Storage
  • Processors Installed Intel Celeron 2.2 GHz
  • RAM Installed ( Max ) 1.0 GB DDR3 SDRAM
  • Hard Drive Standard - 160.0 GB x 1.0 - Serial ATA-300
  • Optical Storage None
  • Storage Removable None
Networking
  • Form Factor Rack-mountable
  • Ports Qty 8.0
  • Connectivity Technology Wired
  • Data Link Protocol Ethernet,
    Fast Ethernet,
    Gigabit Ethernet
More information is here: https://www.itinstock.com/astaro-security-gateway-220-asg220-network-firewall-security-appliance-8822-p.asp
I agree with @pirateghost, VyOS should work on this HW.
Even with the Celeron processor?
No problems there?
Celeron this is x86/x86_64 arch CPU, VyOS should work on all known x86/x86_64
Ok thank you very much for your help.
You can upgrade your hard to an SSD like SAS 6GBPS SSD/3.84TB-2.5Inch for better performance
