Hello all.
First post on the forum.
I’ve been trying to install VyOS 1.1.8 on a PCEngines APU2C4, following the guide at https://wiki.vyos.net/wiki/Network_appliances#PC_Engines_APU2C4 but seem to hitting a wall.
I’ve successfully created the ISO image as laid out in the steps, confirmed the generated ISO boots by running it in a VM, written the ISO to a SDCard (even tried USB stick). I get the syslinux boot explaining to login as vyos/vyos and how to install the image. Once it passes that, I see exactly one kernel message then it appears to hang. The last message I see is “i8042: No controller found”.
Any suggestions or ideas I can try to get VyOS to boot?
Update:
Here’s the serial output from a VM to confirm it’s working:
[code]
ISOLINUX 4.02 debian-20101014 Copyright (C) 1994-2010 H. Peter Anvin et al
* - Welcome to VyOS, an open source network operating system! *
* - Version: 1.1.8 (Helium) *
* - Default login: vyos *
- Default password: vyos *
* - To start installation, login and use command: *
install image * -
Press control and F then 1 for help, or ENTER to
boot:
[ 1.877635] sd 2:0:0:0: [sda] Assuming drive cache: write through
[ 1.879885] sd 2:0:0:0: [sda] Assuming drive cache: write through
[ 1.881046] sd 2:0:0:0: [sda] Assuming drive cache: write through
[ 3.722180] piix4_smbus 0000:00:07.3: Host SMBus controller not enabled!
Welcome to VyOS - vyos ttyS0
vyos login: [/code]
