Hi all - was hoping to benefit from the community collective to see whether there was any experience with installing and running vyos on xcp-ng.
I want to test out running this hypervisor on my Protectli fw6c device (https://protectli.com/product/fw6c/) and virtualise my router along with a bunch of other functions and devices (domain controller, pi-hole DNS, etc, etc).
Before I dig in over the weekend just wanted to know if there are any guides, information, tip etc. available here. In particular I was looking for guidance on basic installation and also setting up vlans to vyos running on top of xcp-ng.
currently there is no special documentation for xcp-ng. I personal never used, so would try to install it via the iso file, the same way as on a bare metal device. If you found something special we can add it to the documentation.
its depends on what you have and what you know. i in personal have a lot of bare metal hosts and some on vmware. The vm-tools are included in the iso, so ist runs smooth.
some time ago i used it on proxmox, also with good results. I my lab (eve-ng) qemu is used.
I have run these op proxmox and xcp-ng they all work for normal usage …vmware i think and this is only from what i have seen …is the only one were you can have groups of thernets linked together…
like 1 eth (real one hardware based)
virtual devices that dont point out… difficult to explain … think they visualise it better aswell…
Im talking about segregating certain vms from each other … some behind nat and some not … and some in groups so they can see each other but no one else…
well if you looking at setting up a few vyos instances for testing …maybe have a look at GNS3 …its a system that lets you test things and links before you go into production.
thanks for the tip, I will look into that for sure.
this is just for my home internet connection and I am the only user so can suffer downtime with no issues
I think I need some pointers on what I should be bringing up and down in the fail and master scripts for VRRP. I will start my research and reading this week.
