Hello, I have a Supermicro X10SDV-TP8F which has an Intel X552 onboard that I am trying to get working with VyOS. The system recognizes the interfaces and even relabels them (to eth6/eth7) however if I try to assign an IP address or any other settings I get errors when committing. For example, after setting an IP address on the interface I get the following:
Could not set flowcontrol for eth7
[ interfaces ethernet eth7 ]
https://support.vyos.io/
- Make sure you are running the latest version of VyOS available at:
https://vyos.net/get/
- Consult the community forum to see how to handle this issue:
https://forum.vyos.io
- Join us on Slack where our users exchange help and advice:
https://vyos.slack.com
business policy requires it)
Report time: 2023-05-02 18:24:48
Image version: VyOS 1.4-rolling-202305010317
Release train: current
Built by: [email protected]
Built on: Mon 01 May 2023 03:17 UTC
Build UUID: 9d08b14d-b7a9-4275-8b17-db00820bcca9
Build commit ID: 88be901bc103d1
Architecture: x86_64
Boot via: installed image
System type: bare metal
Hardware vendor: Supermicro
Hardware model: SYS-5018D-FN8T
Hardware S/N:
Hardware UUID:
File "/usr/libexec/vyos/conf_mode/interfaces-ethernet.py", line 220, in <module>
apply(c)
File "/usr/libexec/vyos/conf_mode/interfaces-ethernet.py", line 209, in apply
e.update(ethernet)
File "/usr/lib/python3/dist-packages/vyos/ifconfig/ethernet.py", line 374, in update
self.set_speed_duplex(speed, duplex)
File "/usr/lib/python3/dist-packages/vyos/ifconfig/ethernet.py", line 172, in set_speed_duplex
return self._cmd(cmd)
File "/usr/lib/python3/dist-packages/vyos/ifconfig/control.py", line 52, in _cmd
return cmd(command, self.debug)
File "/usr/lib/python3/dist-packages/vyos/util.py", line 161, in cmd
raise OSError(code, feedback)
OSError: [Errno 75] failed to run command: ethtool --change eth7 autoneg on
returned:
exit code: 75
noteworthy:
cmd 'ethtool --pause eth7 autoneg on tx on rx on'
returned (out):
returned (err):
netlink error: Invalid argument
cmd 'ethtool --change eth7 autoneg on'
returned (out):
returned (err):
netlink error: link settings update failed
[[interfaces ethernet eth7]] failed
Commit failed
If I try to set disable-flow-control on the interface I get a similar message:
Report time: 2023-05-02 18:43:27
Hardware S/N:
Hardware UUID:
apply(c)
e.update(ethernet)
returned:
exit code: 75
noteworthy:
returned (out):
returned (err):
Commit failed
Hopefully some helpful information:
$ ethtool -I eth7
Settings for eth7:
Supported ports: [ FIBRE ]
Supported link modes: 10000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: No
Supported FEC modes: Not reported
Advertised link modes: 10000baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: No
Advertised FEC modes: Not reported
Speed: 10000Mb/s
Duplex: Full
Auto-negotiation: off
Port: FIBRE
PHYAD: 0
Transceiver: internal
Supports Wake-on: d
Wake-on: d
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
$ lspci | grep Eth
04:00.0 Ethernet controller: Intel Corporation Ethernet Connection X552 10 GbE SFP+
04:00.1 Ethernet controller: Intel Corporation Ethernet Connection X552 10 GbE SFP+
07:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
08:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
0b:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
0b:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
0b:00.2 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
0b:00.3 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
Anything that I am doing wrong or missing?
Thanks
EDIT: Looks like this might be related to T3891. Anyway I can help further troubleshoot this?
