Intel X710-da4 card (4x10 SFP+ 10Gb)
Can I use the Intel X710-da4 card in Vyos? I install, but not load driver…
The result of lspci:
02:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
02:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
02:00.2 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
02:00.3 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 02)
Thanks
Which Vyos version? Has to be one of the newer ones to support this card - 1.1.x does not.
vyos@vyos# run show version
Version: VyOS 1.2.0-rolling+201906070337
Built by: [email protected]
Built on: Fri 07 Jun 2019 03:37 UTC
Build UUID: a7de84f7-02cb-48ce-883b-c57611a62030
Build Commit ID: 08eaa95a34ca63
Architecture: x86_64
Boot via: installed image
System type: bare metal
Hardware vendor: Supermicro
Hardware model: X9SCL/X9SCM
Hardware S/N: Unknown
Hardware UUID: Unknown
Can you send the output of show system kernel-messages?
i have the same problem:
vyos@vyos:~$ show version
Version: VyOS 1.2.0-rolling+201906140337
Built on: Fri 14 Jun 2019 03:37 UTC
Build UUID: 155002df-89dc-46ca-b44e-bbd6ff462eb3
Hardware model: X10SLM±LN4F
But i can not send the show system kernel-messages cause its too long.
I build my own iso by the documentation. When i install from rolling release command “modprobe i40e” tells that module has incorrect symbol.
Version: VyOS 999.201906170708
Built on: Mon 17 Jun 2019 07:08 UTC
Build UUID: 11e26dba-3f45-4f5f-b6b4-795e145ebf8b
Build Commit ID: 1f9fdad4697ace
Hardware model: Super Server
Hardware S/N: 0123456789
Hardware UUID: 00000000-0000-0000-0000-ac1f6b797a18
@jokohp could you run show system kernel-messages | grep i40 and show the output?
Please try again with the latest rolling release from https://vyos.io
vyos@vyos:~$ show system kernel-messages | grep i40
[ 13.747773] i40e: Unknown symbol i40e_get_fw_lldp_status (err -2)
[ 13.768852] i40e: Unknown symbol i40e_get_fw_lldp_status (err -2)
[ 13.793082] i40e: Unknown symbol i40e_get_fw_lldp_status (err -2)
[ 13.812933] i40e: Unknown symbol i40e_get_fw_lldp_status (err -2)
I reinstall the vyos with the last version and now it’s ok.
Version: VyOS 1.2.0-rolling+201906210337
vyos@vyos# run show system kernel-messages |grep i40
[ 12.925444] i40e: Intel® 40-10 Gigabit Ethernet Connection Network Driver - version 2.7.29
[ 12.925444] i40e: Copyright© 2013 - 2018 Intel Corporation.
[ 12.936988] i40e 0000:02:00.0: fw 6.0.48442 api 1.7 nvm 6.01 0x80003494 0.0.0
[ 13.180267] i40e 0000:02:00.0: MAC address: 6c:b3:11:51:35:28
[ 13.184599] i40e 0000:02:00.0: PCI-Express: Speed 5.0GT/s Width x8
[ 13.184600] i40e 0000:02:00.0: PCI-Express bandwidth available for this device may be insufficient for optimal performance.
[ 13.184600] i40e 0000:02:00.0: Please move the device to a different PCI-e link with more lanes and/or higher transfer rate.
[ 13.185020] i40e 0000:02:00.0: Features: PF-id[0] VFs: 32 VSIs: 34 QP: 8 RSS FD_ATR FD_SB NTUPLE CloudF VxLAN Geneve NVGRE PTP VEPA
[ 13.196481] i40e 0000:02:00.1: fw 6.0.48442 api 1.7 nvm 6.01 0x80003494 0.0.0
[ 13.460044] i40e 0000:02:00.1: MAC address: 6c:b3:11:51:35:2a
[ 13.464199] i40e 0000:02:00.1: PCI-Express: Speed 5.0GT/s Width x8
[ 13.464200] i40e 0000:02:00.1: PCI-Express bandwidth available for this device may be insufficient for optimal performance.
[ 13.464200] i40e 0000:02:00.1: Please move the device to a different PCI-e link with more lanes and/or higher transfer rate.
[ 13.464620] i40e 0000:02:00.1: Features: PF-id[1] VFs: 32 VSIs: 34 QP: 8 RSS FD_ATR FD_SB NTUPLE CloudF VxLAN Geneve NVGRE PTP VEPA
[ 13.475375] i40e 0000:02:00.2: fw 6.0.48442 api 1.7 nvm 6.01 0x80003494 0.0.0
[ 13.736452] i40e 0000:02:00.2: MAC address: 6c:b3:11:51:35:2c
[ 13.756920] i40e 0000:02:00.2: PCI-Express: Speed 5.0GT/s Width x8
[ 13.756921] i40e 0000:02:00.2: PCI-Express bandwidth available for this device may be insufficient for optimal performance.
[ 13.756922] i40e 0000:02:00.2: Please move the device to a different PCI-e link with more lanes and/or higher transfer rate.
[ 13.766105] i40e 0000:02:00.2: Features: PF-id[2] VFs: 32 VSIs: 34 QP: 8 RSS FD_ATR FD_SB NTUPLE CloudF VxLAN Geneve NVGRE PTP VEPA
[ 13.777336] i40e 0000:02:00.3: fw 6.0.48442 api 1.7 nvm 6.01 0x80003494 0.0.0
[ 14.039041] i40e 0000:02:00.3: MAC address: 6c:b3:11:51:35:2e
[ 14.081846] i40e 0000:02:00.3: PCI-Express: Speed 5.0GT/s Width x8
[ 14.081848] i40e 0000:02:00.3: PCI-Express bandwidth available for this device may be insufficient for optimal performance.
[ 14.081849] i40e 0000:02:00.3: Please move the device to a different PCI-e link with more lanes and/or higher transfer rate.
[ 14.082270] i40e 0000:02:00.3: Features: PF-id[3] VFs: 32 VSIs: 34 QP: 8 RSS FD_ATR FD_SB NTUPLE CloudF VxLAN Geneve NVGRE PTP VEPA
[ 14.152110] i40e 0000:02:00.0 eth2: renamed from eth0
[ 14.175146] i40e 0000:02:00.3 eth5: renamed from eth1
