Does anyone have any ideas how I can get some nice graphs for VyOS?
Like throughput per interface, cpu utilization and so on?
I tried importing the prometheus-client into my Grafana instance, it worked but I had to build the dashboard myself which is a lot of work, I want something that will figure out everything itself and create the graphs without me having to add all them one by one.
I use LibreNMS to graph and monitor VyOS. By default LibreNMS includes the template for VyOS systems, so it will automatically create all the graphs for you.
I use Zabbix against Vyos. It’s not “pretty” but it shows the data I need.
I am looking forward to being able to use 1.4 as it has Zabbix client built in!!
