I am setting up VyOS.. 7 interfaces in VM exists (vmmic is connected and defined)
First 6 setup correctly. but the 7th is no dice
unable to commit and save
I already rebooted, and Tried a new install.
Same no good.
Advice?
Same no good.
Advice?
As far as I know, VyOS has no limit on the number of interfaces
I tried to make 10 interfaces and set up IP addresses on them.
Everything worked (commit and save):
vyos@vyos:~$ sh interfaces
eth0 192.168.6.129/24 u/u
eth1 192.168.101.1/24 u/u
eth2 192.168.102.1/24 u/u
eth3 192.168.103.1/24 u/u
eth4 192.168.104.1/24 u/u
eth5 192.168.105.1/24 u/u
eth6 192.168.106.1/24 u/u
eth7 192.168.107.1/24 u/u
eth8 192.168.108.1/24 u/u
eth9 192.168.109.1/24 u/u
lo 127.0.0.1/8 u/u
::1/128
What version of VyOS do you use?
sh version
Hi @digital_kungfu , any logs/errors during commit? What are the exact changes you’re applying when the issue occurs?
Please show output of:
compare
commit
