I have configured a tunnel between vyos and Paloalto and Paloalto is behind NAT. Once tunnel is established I am running command “test vpn ike-sa” on Paloalto. Paloalto start creating new child_sa and does not send delete child_sa request for old child_sa. vyos gets new child_sa request and start deleting old child_sa. vyos send delete child_sa request to Paloalto for old child_sa but since Paloalto has already deleted old sa it does not respond to delete request. vyos sends delete request for 5 tumes and deactivate vti0.
I am getting following logs in charon.log:
Jun 14 06:11:41 14[IKE] <peer-10.15.18.12-tunnel-vti|2> giving up after 5 retransmits
Jun 14 06:11:41 14[IKE] <peer-10.15.18.12-tunnel-vti|2> proper IKE_SA delete failed, peer not responding
Jun 14 06:11:41 13[KNL] interface vti0 deactivated
IPSEC.CONF
generated by /opt/vyatta/sbin/vpn-config.pl
config setup
interfaces="%none"
nat_traversal=yes
conn %default
keyexchange=ikev1
conn peer-10.15.18.12-tunnel-vti
left=10.15.20.119
leftid=“100.64.0.1”
right=10.15.18.12
rightid=“100.64.0.2”
leftsubnet=0.0.0.0/0
rightsubnet=0.0.0.0/0
ike=aes128-sha1-modp2048,aes128-md5-ecp256,aes128-sha256-modp1024,aes128-sha384-modp1024!
keyexchange=ikev2
reauth=no
ikelifetime=86400s
dpddelay=30s
dpdtimeout=120s
closeaction=none
dpdaction=restart
esp=aes128-sha1-modp1024,aes256-md5-modp1024,aes256-sha256-modp1024,aes128-md5-modp1024,aes128-sha256-modp1024!
keylife=43200s
rekeymargin=540s
type=tunnel
compress=no
authby=secret
mark=9437185
leftupdown="/usr/lib/ipsec/vti-up-down vti0"
auto=add
keyingtries=1
#conn peer-10.15.18.12-tunnel-vti
vyos is in responder mode. how can I make sure that when delete request from vyos does not get responded vti0 should not go down.
