i am confused i have load a config from my version of may and now I have the error to load the config at the current release from today.
password was not changed
commit
[ system login user vyos authentication encrypted-password $6=656000$/AwQvflRJNQHQrD./S/fsgG6m/w8ksr6gABvaBQtaBL65F53CjRwLAhw77mRPNOoT00 ]
Invalid encrypted password for vyos.
[[system login]] failed
Version: VyOS 1.4-rolling-202307060317
Release train: current
Built by: autobuild@vyos.net
Built on: Thu 06 Jul 2023 03:17 UTC
Build UUID: e3993fe1-c747-4bd2-a3aa-9b23bfb77f03
Build commit ID: 934bccc686d764
Architecture: x86_64
Boot via: installed image
System type: VMware guest
Hardware vendor: VMware, Inc.
Hardware S/N: VMware-42 1c 3a b5 7c 4a 12 3d-d3 c4 d1 e5 e5 03 e9 10
Hardware UUID: b53a1c42-4a7c-3d12-d3c4-d1e5e503e910
Hi @tomcat667
I tested your encrypt password with vyos 1.3.1 LTS release version. Still error. Would please check your encrypted password right?
BTW with right encrypt password at my side. I can set without any issue.
set system login user testing123 authentication encrypted-password $6=656000$/AwQvflRJNQHQrD./S/fsgG6m/w8ksr6gABvaBQtaBL65F53CjRwLAhw77mRPNOoT00
Invalid encrypted password for testing123.
Value validation failed
Set failed
Hi @tomcat667 and @echowings.
As you know VyOS is an open source network operating system based on Debian GNU/Linux.
Inside Debian all passwords stores in /etc/shadow file and with sha512 encrypted(hashed) format.
If you want to pass encrypted password to the system:
- Encrypt your plaintext password to sha512
- Use quotas ’ ’ and pass your encrypted password to the system.
For example:
set system login user tech authentication encrypted-password ‘$6$ap2BCXTWLnyXd3$qWiZaC0T9RV1508miq69oe1tLVbFT.KqoMtxnmW8fDmZeCaCm/3jjdWtTiFmlYsmAgQ7fjLbmgmFQ93Pj3GFE1’
For encryption your plaintext password you may install and use tools then copy and paste.
Or you just instead of using encrypted-password you may use plaintext-password.
For example:
set system login user test authentication plaintext-password test
After the committing your password will be encrypt and store in the system.
Isnt it salted SHA512 by now?
I do not think so.
For testing purpose I have used in Linux:
mkpasswd -m sha-512 ‘your-password’
Then copied output (hashed password) pasted.
Worked without any problem.
Sha-512 is hashing algorithm. A hashing algorithm is a mathematical function that garbles data and makes it unreadable. Hashing algorithms are one-way, so the text can’t be unscrambled and decoded by anyone else.
The shadow-file supports many formats.
The way Debian and other modern linux distributions stores passwords in the shadow-file is in salted form.
For example $6$$
Hashing algorithms without a salt are vulnerable to precomputed rainbowstables.
You can of course precompute a rainbowtable for a given salt aswell but it will take some time.
There are also implementations with number of rounds to make creation of rainbowstables even slower.
