Not sure if this is a bug or not, so if not, please move to the correct category.
vyos@vyos:~$ show version
Version: VyOS 1.3-rolling-202006241940
Release Train: equuleus
Built by: autobuild@vyos.net
Built on: Wed 24 Jun 2020 19:40 UTC
Build UUID: 35acaac7-e83c-430d-915f-8e63670c8178
Build Commit ID: f2f6332ca1acd9
Architecture: x86_64
Boot via: installed image
System type: KVM guest
Hardware vendor: OpenStack Foundation
Hardware model: OpenStack Nova
Hardware S/N: Unknown
Hardware UUID: Unknown
Interfaces
vyos@vyos:~$ show interfaces
eth1 10.10.100.1/24 u/u
eth2 A.A.A.A/24 u/u
lo 127.0.0.1/8 u/u
::1/128
Relevant Config
set vpn ipsec esp-group remote-esp compression 'disable'
set vpn ipsec esp-group remote-esp lifetime '3600'
set vpn ipsec esp-group remote-esp mode 'tunnel'
set vpn ipsec esp-group remote-esp pfs 'disable'
set vpn ipsec esp-group remote-esp proposal 1 encryption 'aes256'
set vpn ipsec esp-group remote-esp proposal 1 hash 'sha1'
set vpn ipsec ike-group remote-ike ikev2-reauth 'no'
set vpn ipsec ike-group remote-ike key-exchange 'ikev1'
set vpn ipsec ike-group remote-ike lifetime '28800'
set vpn ipsec ike-group remote-ike proposal 1 dh-group '2'
set vpn ipsec ike-group remote-ike proposal 1 encryption '3des'
set vpn ipsec ike-group remote-ike proposal 1 hash 'sha1'
set vpn ipsec ipsec-interfaces interface 'eth2'
set vpn ipsec nat-traversal 'enable'
set vpn ipsec site-to-site peer B.B.B.B authentication mode 'pre-shared-secret'
set vpn ipsec site-to-site peer B.B.B.B authentication pre-shared-secret 'secret'
set vpn ipsec site-to-site peer B.B.B.B default-esp-group 'remote-esp'
set vpn ipsec site-to-site peer B.B.B.B ike-group 'remote-ike'
set vpn ipsec site-to-site peer B.B.B.B local-address 'A.A.A.A'
set vpn ipsec site-to-site peer B.B.B.B tunnel 1 local prefix '10.10.100.0/24'
set vpn ipsec site-to-site peer B.B.B.B tunnel 1 remote prefix '10.10.0.0/24'
Tunnel is up
vyos@vyos:~$ show vpn ipsec sa
Connection State Uptime Bytes In/Out Packets In/Out Remote address Remote ID Proposal
peer-B.B.B.B-tunnel-1 up 10m15s 0B/0B 0/0 B.B.B.B N/A AES_CBC_256/HMAC_SHA1_96
Looks normal
vyos@vyos:~$ show vpn debug
Status of IKE charon daemon (strongSwan 5.7.2, Linux 4.19.128-amd64-vyos, x86_64):
uptime: 11 minutes, since Jun 30 15:14:40 2020
malloc: sbrk 2945024, mmap 0, used 1119632, free 1825392
worker threads: 11 of 16 idle, 5/0/0/0 working, job queue: 0/0/0/0, scheduled: 2
loaded plugins: charon test-vectors ldap pkcs11 tpm aesni aes rc2 sha2 sha1 md5 mgf1 rdrand random nonce x509 revocation constraints pubkey pkcs1 pkcs7 pkcs8 pkcs12 pgp dnskey sshkey pem openssl gcrypt af-alg fips-prf gmp curve25519 agent chapoly xcbc cmac hmac ctr ccm gcm curl attr kernel-netlink resolve socket-default connmark stroke vici updown eap-identity eap-aka eap-md5 eap-gtc eap-mschapv2 eap-radius eap-tls eap-ttls eap-tnc xauth-generic xauth-eap xauth-pam tnc-tnccs dhcp lookip error-notify certexpire led addrblock counters
Listening IP addresses:
A.A.A.A
Connections:
peer-B.B.B.B-tunnel-1: A.A.A.A...B.B.B.B IKEv1
peer-B.B.B.B-tunnel-1: local: [A.A.A.A] uses pre-shared key authentication
peer-B.B.B.B-tunnel-1: remote: [B.B.B.B] uses pre-shared key authentication
peer-B.B.B.B-tunnel-1: child: 10.10.100.0/24 === 10.10.0.0/24 TUNNEL
peer-B.B.B.B-tunnel-1[1]: ESTABLISHED 11 minutes ago, A.A.A.A[A.A.A.A]...B.B.B.B[B.B.B.B]
peer-B.B.B.B-tunnel-1[1]: IKEv1 SPIs: 085d93c9bdbc5ad8_i* 63bd0b0a10a5488e_r, pre-shared key reauthentication in 7 hours
peer-B.B.B.B-tunnel-1[1]: IKE proposal: 3DES_CBC/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024
peer-B.B.B.B-tunnel-1{1}: REKEYED, TUNNEL, reqid 1, expires in 48 minutes
peer-B.B.B.B-tunnel-1{1}: 10.10.100.0/24 === 10.10.0.0/24
peer-B.B.B.B-tunnel-1{2}: INSTALLED, TUNNEL, reqid 1, ESP SPIs: cf1d245e_i c4a0545c_o
peer-B.B.B.B-tunnel-1{2}: AES_CBC_256/HMAC_SHA1_96, 0 bytes_i, 0 bytes_o, rekeying in 35 minutes
peer-B.B.B.B-tunnel-1{2}: 10.10.100.0/24 === 10.10.0.0/24
Policy
vyos@vyos:~$ show vpn ipsec policy
src 10.10.100.0/24 dst 10.10.0.0/24
dir out priority 375423 ptype main
tmpl src A.A.A.A dst B.B.B.B
proto esp spi 0xc4a0545c reqid 1 mode tunnel
src 10.10.0.0/24 dst 10.10.100.0/24
dir fwd priority 375423 ptype main
tmpl src B.B.B.B dst A.A.A.A
proto esp reqid 1 mode tunnel
dir in priority 375423 ptype main
src 0.0.0.0/0 dst 0.0.0.0/0
socket in priority 0 ptype main
socket out priority 0 ptype main
src ::/0 dst ::/0
src ::/0 dst ::/0
src ::/0 dst ::/0
src ::/0 dst ::/0
PROBLEM.
10.10.100.50/24 => VYOS [10.10.100.1] <internet> [B.B.B.B] -- 10.10.0.1/24
The default gateway for 10.10.100.50 is 10.10.100.1, which is the vyos.
The tunnel is up, but both sides cannot ping each other.
If I do trace-route 10.10.0.1 from 10.10.100.50, it tries to go out from the default router of the vyos … and does not hit 10.10.0.1 or B.B.B.B
The IP tries to go via the default gateway in the vyos and not via the tunnel.
Bytes in/out over the tunnel is zero.
There are no firewalls anywhere.
The other end is a cisco I do not have access to.
