IPV6 as a Dual stack with IPV4 on VYOS using PPPOE and Radius Server
Hello Guys,
I’m trying to configure the dual stack in Vyos 1.5 rolling version. After config IPv6 and IPv4 PPPoE Local Pool IPs set in my device I checked Google " my IP address status " it showed IPv4 Public IP only IPv6 Public IP is not detected. Give the solution for this issue
My Router Config:
ridsys@RIDSYS-BRAS-Vyos:~$ show configuration
address 103.183.46.66/30
description WAN-INPUT
address 192.168.1.1/24
description LOCAL-LAN
ethernet eth2 {
description PPPoE-Out
duplex auto
speed auto
ethernet eth3 {
address 2001:df0:84c0:4::3/126
description IPv6-WAN-Input
ethernet eth4 {
address 2001:db8::1/64
description IPv6-LOCAL-LAN
loopback lo {
nat {
rule 12 {
outbound-interface eth0
address 192.168.1.0/24
translation {
address masquerade
rule 100 {
protocol tcp_udp
address 10.20.112.0/20
translation {
ethernet eth2 {
duplex auto
speed auto
ethernet eth3 {
ethernet eth4 {
loopback lo {
:…skipping…
ethernet eth2 {
duplex auto
speed auto
ethernet eth3 {
ethernet eth4 {
loopback lo {
nat {
rule 12 {
translation {
address masquerade
rule 100 {
protocol tcp_udp
translation {
address 103.183.46.40/29
options {
address-mapping persistent
nat66 {
rule 112 {
outbound-interface eth3
protocol all
prefix 2001:db8:8003::/56
translation {
address masquerade
protocols {
static {
route 0.0.0.0/0 {
next-hop 103.183.46.65 {
route6 ::/0 {
next-hop 2001:df0:84c0:4::1 {
service {
dhcp-server {
shared-network-name LAN {
authoritative
subnet 192.168.1.0/24 {
default-router 192.168.1.1
lease 86400
name-server 8.8.8.8
name-server 8.8.4.4
ping-check
range 0 {
start 192.168.1.100
stop 192.168.1.200
dhcpv6-server {
shared-network-name IPv6-LAN {
common-options {
name-server 2001:db8::fff
subnet 2001:db8::/64 {
address-range {
start 2001:db8::100 {
stop 2001:db8::200
ntp {
allow-client {
address 0.0.0.0/0
address ::/0
server time1.vyos.net {
server time2.vyos.net {
server time3.vyos.net {
pppoe-server {
access-concentrator PPPoE
authentication {
mode radius
protocols pap
radius {
dynamic-author {
key ****************
port 3799
server 103.183.46.6
nas-identifier RIDSYS-BRAS-Vyos
nas-ip-address 103.183.46.66
rate-limit {
attribute Mikrotik-Rate-Limit
enable
vendor mikrotik
server 103.183.46.6 {
acct-port 1813
port 1812
source-address 103.183.46.66
client-ip-pool {
start 10.20.112.2
stop 10.20.127.254
subnet 10.20.112.0/20
client-ipv6-pool {
delegate 2001:db8:8003::/48 {
delegation-prefix 56
prefix 2001:db8:8002::/48 {
mask 64
gateway-address 10.20.112.1
interface eth2 {
vlan 100
vlan 200
name-server 8.8.8.8
name-server 8.8.4.4
name-server 2001:4860:4860::8888
name-server 2001:4860:4860::8844
ppp-options {
ipv6 allow
router-advert {
interface eth4 {
prefix ::/64 {
ssh {
access-control {
allow {
port 1024
system {
config-management {
commit-revisions 100
conntrack {
modules {
ftp
h323
nfs
pptp
sip
sqlnet
tftp
console {
device ttyS0 {
speed 115200
host-name RIDSYS-BRAS-Vyos
login {
user ridsys {
authentication {
name-server 8.8.8.8
name-server 8.8.4.4
syslog {
global {
facility all {
level info
facility local7 {
level debug
time-zone Asia/Kolkata
can you please share the DHCPv6 server configuration with NATing . Internet not working only the LAN IP pool set in my host
@bella your example config is a bit hard to follow as you’re using example IPv6 addresses for parts of it and then your ::/0 route goes to 2001:df0:84c0: but eth3 is 2001:XXXXX:4::3/126 which it’s not clear whether that’s the same subnet.
It could be as simple as a bad route? I’m not familiar with running a PPPoE server but it also appears to be missing the advertisement of an IPv6 route, unless that part is automatic I actually don’t know.
I can understand plz check once again my config. I will share the full details without xxx.
note: i will attached the google my ip status image ( only IPv4 showing )
status image
Maybe a dumb question but can you ping upstream IPv6 from VyOS itself? For eg. 2001:4860:4860::8888
It was pinging fine.
