Hello, we are having an issue with ipv6 BGP peering. Our /64 range is not being advertised.
Config is as follows:
set protocols bgp 33XXX neighbor 2001:X:X:XX::XX:X address-family ipv6-unicast route-map export 'COGENT-OUT-IPV6'
set protocols bgp 33XXX neighbor 2001:X:X:XX::XX:X address-family ipv6-unicast route-map import 'COGENT-IN-IPV6'
set protocols bgp 33XXX neighbor 2001:X:X:XX::XX:X address-family ipv6-unicast soft-reconfiguration inbound
set protocols bgp 33XXX neighbor 2001:X:X:XX::XX:X remote-as '174'
set protocols bgp 33XXX neighbor 2001:X:X:XX::XX:X update-source '2001:X:X:XX::XX:Y'
set policy route-map COGENT-OUT-IPV6 rule 100 action 'permit'
set policy route-map COGENT-OUT-IPV6 rule 100 match ipv6 address prefix-list 'EXPORT-AS174-IPV6'
set policy prefix-list6 EXPORT-AS174-IPV6 rule 10 action 'permit'
set policy prefix-list6 EXPORT-AS174-IPV6 rule 10 prefix '26XX:XXXX::/36'
set protocols static route6 26XX:XXXX::/36 blackhole distance '254'
vyos@vyos-er01# run show ipv6 bgp neighbors 2001:X:X:XX::XX:X
BGP neighbor is 2001:X:X:XX::XX:X, remote AS 174, local AS 33360, external link
BGP version 4, remote router ID 154.XX.X.XX, local router ID 204.XX.XX.XX
BGP state = Established, up for 00:19:51
Last read 00:00:12, Last write 00:00:51
Hold time is 180, keepalive interval is 60 seconds
Neighbor capabilities:
4 Byte AS: advertised and received
AddPath:
IPv6 Unicast: RX advertised IPv6 Unicast
Extended nexthop: received
Address families by peer:
IPv4 Unicast
Route refresh: advertised and received(old & new)
Address Family IPv6 Unicast: advertised and received
Hostname Capability: advertised (name: debian,domain name: n/a) not received
Graceful Restart Capability: advertised
Graceful restart information:
Local GR Mode: Helper*
Remote GR Mode: Disable
R bit: False
Timers:
Configured Restart Time(sec): 120
Received Restart Time(sec): 0
Message statistics:
Inq depth is 0
Outq depth is 0
Sent Rcvd
Opens: 1 1
Notifications: 0 0
Updates: 0 47106
Keepalives: 20 2
Route Refresh: 0 0
Capability: 0 0
Total: 21 47109
Minimum time between advertisement runs is 0 seconds
Update source is 2001:X:X:XX::XX:Y
For address family: IPv6 Unicast
Update group 1, subgroup 1
Packet Queue length 0
Inbound soft reconfiguration allowed
Community attribute sent to this neighbor(all)
Inbound path policy configured
Outbound path policy configured
Route map for incoming advertisements is *COGENT-IN-IPV6
Route map for outgoing advertisements is *COGENT-OUT-IPV6
67548 accepted prefixes
Connections established 1; dropped 0
Last reset 00:19:53, Waiting for peer OPEN
Local host: 2001:X:X:XX::XX:Y, Local port: 39125
Foreign host: 2001:X:X:XX::XX:X, Foreign port: 179
Nexthop: 38.XX.XX.XX
Nexthop global: 2001:X:X:XX::XX:Y
Nexthop local: feXX::XXXX:XXX:XXX:XXzz
BGP connection: shared network
BGP Connect Retry Timer in Seconds: 120
Read thread: on Write thread: on FD used: 31
I am able to receive full routing tables on both ipv4 and ipv6. My ipv4 routes are being advertised correctly.
